05-22-2008, 12:00 PM   #1 (permalink)
SLCK64
Mercury 410
I heard that special pistons have to be made to make Mercury 410(390 with 428 crank)?
'64 Merc Comet Caliente MoreDoor....
SLCK64 is offline   Reply With Quote
05-22-2008, 12:18 PM   #2 (permalink)
unioncreek
Re: Mercury 410
I think if you'd post this over in the Galaxie forum you'll get quite a bit of info. If I remember right my old pickup had 410 pistons in it and it was a 390. The only difference between the 410 and 390 is the crank. Piston/valve clearance would have to be checked.
Bob
Bob G
1962 Galaxie 500 XL with a 390 Thunderbird Special.
unioncreek is offline   Reply With Quote
05-22-2008, 02:10 PM   #3 (permalink)
PistonDude
Re: Mercury 410
Probe/Coast High performance has a .030 over flat tp piston for the Merc 410
PistonDude is offline   Reply With Quote
05-26-2008, 04:13 PM   #4 (permalink)
doug351
Re: Mercury 410
Bob
I don't know much about these engines, but I did find listings for both 390 and 410 pistons, and they are not the same compression height. The 390's are taller and would probably hit the valves, if not the head. So to answer the original question- yes, you have to use 410 pistons, but they are available, so they don't have to be specially made.
doug351 is offline   Reply With Quote
06-01-2008, 12:44 PM   #5 (permalink)
iwantmore
Re: Mercury 410
I agree except It is really a 410 crank in the 428 since it came first. The 428 has the 406 bore of 4.13. The 390 and 410 share a 4.05 bore and same rods. Piston pin is .10 higher in the 410 piston.
06-01-2008, 04:09 PM   #6 (permalink)
BIGJOE
Re: Mercury 410
I have bored at 390 out to std 428 bore size, then when you get a 428 crank, you end up with 428 cubic inches from a 390 block. I know it has been done many times before.
JOE SHERMAN RACING ENGINES
06-02-2008, 08:23 PM   #7 (permalink)
Gearhead99
Re: Mercury 410
Yep, done many, many times.
And looks like a 390 cu in from outside. Just has a lot of "punch". FE's look pretty much the same externally.
"Support our Troops"
2007 F-150 "Harley-Davidson", SuperCrew
2004 Thunderbird
1968 Cougar, 347 stroker, dual AFB's
1986 LTD
Gearhead99 is offline   Reply With Quote
59 monarch or mercury 4 dr sceptre Wanted 1 03-15-2008 01:50 AM
63 mercury meter s33 donald Vehicles for Sale 0 02-16-2008 06:58 PM
Help with Mercury Mystic jims67XL All Ford Techboard 5 09-10-2004 11:14 PM
59 Mercury value Rodney The Garage 4 05-17-2004 11:08 PM
05 Mercury Montego.... deleted3 The Garage 7 02-13-2003 01:33 PM
