06-01-2008, 09:38 PM   #1 (permalink)
351Cjunkie
383C or 393C block work
Are there any clearance issues (rod or crank) building a 383C or 393C using a .030 over 351C block? What is the longest rod I can use without notching the block? I am considering the scat 383 or 393 rotating assembly. Block was machine some time ago(bagged and tagged) and has just been setting and waiting for parts $$$s. Thanks
351Cjunkie is offline   Reply With Quote
06-01-2008, 10:08 PM   #2 (permalink)
BIGJOE
Re: 383C or 393C block work
The rod has NOTHING to do with it, The stroke is where the problem lies.
JOE SHERMAN RACING ENGINES
06-02-2008, 04:51 PM   #3 (permalink)
351Cjunkie
Thanks BIGJOE
Ok..I'm all eyes and ears....please tell me more. The only machine work done was, align bore check required a clean up only, cylinder bored 030 with deck plate, and cam bearing in stalled. Oh and magnafluxed sonic check. Do you know if I will need more block work for 3.850 stroke or 3.750 stroke? Thanks
06-04-2008, 02:57 PM   #4 (permalink)
ckelly
I don't recall anyone on 351cleveland.net having any clearance issues with the block in a 377, 383 or 393 motor. It's the piston skirts and crank counterweights that get in each other's way. Depends on the piston and crank.
06-12-2008, 10:54 AM   #5 (permalink)
PSIG
Chris is right, the piston/crank relationship is a primary interference point, so be sure you get a known combo for the fewest issues. Scat is generally pretty good about that area. Actually, there are several checkpoints and some do depend on what rod you use. Some rods are very fat on the big end and will require checking for interference on both the block (pan rail & cylinder bottom areas) and the camshaft. Mock-ups are the word of the day.
To make life easier, you may want to take a rod to the hardware store and look for a stock-sized spring that will fit the piston pin bore and be just over 4" overall. This replaces the piston during some mock-ups and keeps the rod centered in the bore, while allowing more room and visual angles to clearance checking. Oh, and put some chair leg caps on the ends of the springs so they don't rub the bore metal-to-metal. If block clearance is required, it won't be much, and a light hit with a Dremel or die grinder will give the clearance you need. Have fun!
David
Piston/crank clearance - block upside-down on stand. Also note the semi-circle notch on the right side of the cylinder bore for the other rod to clear:
•Fast
•Reliable
•Cheap
Pick two.
07-23-2008, 01:52 AM   #6 (permalink)
fordcarnut
Got a 399 stroker complete engine w/ all mods done professionally built.
12.5:1, around 600 hp. if interested
fordcarnut is offline   Reply With Quote
393C dyno results davis Dyno Board 36 05-19-2007 01:18 PM
E7TE small block heads on C8OE block Kman All Ford Techboard 6 06-08-2006 09:40 AM
383C Durability ? lynched1 Stroker Engines 0 06-11-2005 11:34 AM
351W lightning block vs standard roller block mustangzrule All Ford Techboard 6 08-27-2004 08:53 PM
will these work in 9.480 block steharz All Ford Techboard 2 10-19-2003 04:30 AM
