06-01-2008, 10:15 PM   #1 (permalink)
unfairlane
deburring 302 block
Hey guys I am building a 331 stroker and I am starting with a 68 302 block and before I drop her off at the machine shop I was planning on debburring the block. What areas should I pay attention to? I am already planning on polishing the lifter valley and removing the rib that is on each side of the main caps. What else are some things I can do. i am trying to make this block as strong as possible. And I already know that some of you are going to tell me I am wasting my time, but I am doing it anyways : ) thanks for the help!
Stop tellin me it can't be done or it won't fit... your jus' fuelin my fire!!!!
unfairlane is offline   Reply With Quote
06-02-2008, 08:17 PM   #2 (permalink)
Gearhead99
Re: deburring 302 block
You can polish and relieve around all the oil drain back holes.
Where there is any casting flashing, grind it off.
Any sharp edges can be relieved.
Chamfer the headbolt holes.
When you get the block back from machinest, run a tap through ALL the bolt holes. Keeps you from having a "surprise" later while assembling.
"Support our Troops"
2007 F-150 "Harley-Davidson", SuperCrew
2004 Thunderbird
1968 Cougar, 347 stroker, dual AFB's
1986 LTD
Gearhead99 is offline   Reply With Quote
06-02-2008, 10:15 PM   #3 (permalink)
unfairlane
Other then chamfering the bolt holes that is what I have done so far. Thanks for the advice. There really is not alot to be ground off an old casting sbf. They are nice cast blocks.
Big block radiator with small block 1968 9t3lightning Galaxie Pages 1 10-28-2007 02:32 PM
New 8.20 sbf boss racing block vs worlds block stoker All Ford Techboard 35 12-06-2006 09:23 PM
E7TE small block heads on C8OE block Kman All Ford Techboard 6 06-08-2006 09:40 AM
351W lightning block vs standard roller block mustangzrule All Ford Techboard 6 08-27-2004 08:53 PM
Anyone use a big block fuel pump in a small block? mc All Ford Techboard 4 04-21-2003 02:34 AM
Probe Industries
