06-01-2008, 10:30 PM   #1 (permalink)
Kenny64
347 breather(s) or PCV
Can somebody tell me the best/proper ventilation setup for a carbed 347. Right now i've got a KN type breather in front of both valve covers and no pcv (have a second hole blocked off on rear of drivers side valve cover). Let me know if you need more engine info.
Kenny64 is offline   Reply With Quote
06-02-2008, 02:07 AM   #2 (permalink)
Spali32
Re: 347 breather(s) or PCV
You need to have a PVC on one valve cover and a breather on the other side. It needs to suck the exhaust gases out of the engine and reburn them. If not.....you are asking for trouble down the road. Maybe even a fire.
www.spalisautodetailing.com
347 Stroker/XE284H(284/296 dur, 240/246 dur @ .050), BG 650 VS Speed Demon, Ported Victor Jr intake, Jack Roush World Jr Heads (ported from 180cc to 195cc)(upgraded to 2.02/1.60 valves) 260cfm/190cfm @ .550 lift, 11:1 comp... 450-475HP
06-02-2008, 04:41 AM   #3 (permalink)
Joel50
An "Open PCV System" will work fine. PCV valve on one of the valve covers + open breather on the other valve cover...... you could also leave the 2nd. breather installed, but the PCV vacuum draw will help remove the fumes from the crankcase and allow the engine to stay cleaner and the oil to last longer.
Joel50 is offline   Reply With Quote
06-02-2008, 03:20 PM   #4 (permalink)
87stang
What Joel5.0 said.
The PCV system is supposed to pull nasty crankcase gases through the intake via vacuum and "reburn" it...for emmisions pusrposes as well.
Vented, as you have it, works perfectly fine. You just might get some residue seeping through your filters and onto the valve covers, but it shouldn't be so much so that it becomes a fire hazard. An elevated fill tube might help with this, and in more extreme cases of it some people use an oil/air seperator...either vented or tied into the PCV system (I'm not talking abuot the dinky setups for air compressors either).
Dave
\'87 5.0 LX Hatch, 5-speed
Cobra brakes
CHP 347
06-02-2008, 08:20 PM   #5 (permalink)
Gearhead99
You many times get the "oil smell" from just open breathers. Do you and your engine a favor and install a PCV to relieve the crankcase pressure and oil smell.
"Support our Troops"
2007 F-150 "Harley-Davidson", SuperCrew
2004 Thunderbird
1968 Cougar, 347 stroker, dual AFB's
1986 LTD
Gearhead99 is offline   Reply With Quote
06-03-2008, 05:49 PM   #6 (permalink)
Kenny64
Does the PCV need to be baffled to keep from pulling oil through intake??
06-03-2008, 06:22 PM   #7 (permalink)
Gearhead99
I would baffle it some how.
2004 Thunderbird
1986 LTD
06-04-2008, 09:11 AM   #8 (permalink)
87stang
Yes, a baffle should be used. If that doesn't work, an oil/air seperator as I mentioned is an option, but requires regular maintenance (draining).
Dave
Cobra brakes
CHP 347
Do I need another breather? BLstangin All Ford Techboard 10 11-16-2004 07:01 PM
Oil from breather, or sucking from PCV hirtrobert All Ford Techboard 3 11-07-2004 06:43 AM
fluid out the breather town65 C4 Transmissions 1 05-03-2004 05:38 PM
oil out the breather caps RonM Galaxie Pages 6 02-23-2004 08:18 PM
Closed Cap or Breather? boss302 All Ford Techboard 10 11-15-2002 10:53 AM
Probe Industries
