Originally Posted by $arge
the PO installed the dizzy, im curious, would one tooth off on the dizzy give me dieseling when i shut it down but a good run when i goose it? im just at my witts end with this thing!
Raf
One tooth can make a large difference but still run. Depending on which way the timing jumped, you either have about 9° additional ignition advance or the same in retard (which can cause dieseling), but you'll also have the same amount of camshaft advance/retard. I had a small block do this and the engine ran like crap at low rev's but actually ran pretty good at higher speeds. In my case, the timing advanced and it would ping just trying to drive normally. Since you don't apparently have detonation (ping), that would tend to indicate you have retarded timing and cam - a combo that would do what's happening here.
I would certainly verify your ignition timing first, since it's easy to do, before tearing into the timing cover. In-fact, that should be the first step in all of this, otherwise you're working blind. You can use a borrowed timing light (I bought 2 of mine at yard sales for $5), or use a continuity tester or multimeter, to establish where it's timed now. Get that done first.
I just installed and set timing on a PerTronix the other day with a continuity meter (engine off). When cranked and checked with a timing light I was 1° off of the 10°BTDC I was after. Easy stuff.
Disconnect the PerTronix wires and run a jumper wire from the battery (+) to the red wire. Then hook your meter or tester between the black wire and a good ground. Turn your crank with a socket and breaker bar to your proper idle timing (let's say 10°BTDC) and turn your distributor 1/2" either way. At some point the meter will swing from grounding to open (not grounding). That is your firing point. Carefully find that exact spot and lock your distributor down. It shouldn't be far from where it was. Note that it must be the point that it goes from grounding -> not grounding (or conducting/not conducting), as the opposite is not a firing point. That will set your correct static timing.
To first find where your timing is
now with a meter (to see if you might have jumped a tooth) do as above, but rotate the crank with the wrench instead of the distributor. The PerTronix will change from conducting to non-conducting through the black wire when it would normally fire the coil. Be sure you're doing all this with the engine on the #1 cylinder compression stroke (the rotor should be roughly pointing at the #1 plug wire cap terminal) and with the black wire disconnected from the coil for measuring and so it won't fire. Hope that helps.
David
EDIT: BTW - I'm talking the timing chain jumping a tooth. Not the distributor off 1 tooth as that can be simply adjusted out but the jumped chain can't.
