07-03-2008, 05:30 AM   #1 (permalink)
jwarnick
351w stroked to 438ci what r the best heads
I'm building a 438ci stroker
dart block
eagle crank
eagle h beam rods
je 14.5 to 1 piston
was plaining on the afr heads # 1456 w/225's. This is going to be a all out race engine with two stages of nitrous. Is this the best head to run with this set up ? I have read so much on so many different heads I'm like duhhhhh !!!!
Anyone out there have any advice ?
jwarnick is offline   Reply With Quote
07-03-2008, 06:05 AM   #2 (permalink)
mavman
Re: 351w stroked to 438ci what r the best heads
the 225's will work but I think they are a bit on the small side, IMO. I was going to suggest Victor Sr's but you already have pistons, so they're out. How about a set of high ports? Wait...you'd have to have the pistons cut for those too I believe.
I know if I was doing a dart block 438, I'd put a set of ported Victor Sr's on it and let it eat. Matter of fact, I'm thinking about doing just that....just need to save up the $$$ for the block & heads.
07-03-2008, 06:23 AM   #3 (permalink)
mrtbolt64
Any of the Victor Srs, TFS High Port as mentioned. You spent alot of money on the bottom end, dont skip on the top
1992 mustang lx coupe, caged, mini tubbed, 393 with Novi2k supercharger 11lbs of boost, BS3 EFI on 93 octane. 9.47 @144
1997 F350 psd 4x4 http://media.putfile.com/Mustang-Novi2k
mrtbolt64 is offline   Reply With Quote
07-03-2008, 07:01 AM   #4 (permalink)
MY TWO STANGS
The world products Man-O-war are the best but there a little high. A set of AFR 225 would be the best bet that is with in reasonable reach .
07-03-2008, 12:12 PM   #5 (permalink)
BLstangin
My 438 made 615hp on pump gas with a 252/260, .649lift cam 114lsa and 10.6 compression with afr 225 heads and a ported super victor. With more compression and cam who knows???
1970 mustang coupe restored with the help of my dad soon to be 438 dart block based stroker, afr 225, super victor,BIGS 950hp, accufab 2\" primary headers, solid roller cammed, 4speed toploader, 9\" 3.50 gears, locker
BLstangin is offline   Reply With Quote
07-03-2008, 05:54 PM   #6 (permalink)
fastcoupe68
TFS R heads ported by a reputable company and you will make lots and lots of horsepower, just to name one. There are a few cylinder heads you can go with that will make lots more power over an out of box head, If you use a company that knows what there doing
fastcoupe68 is offline   Reply With Quote
07-04-2008, 01:39 AM   #7 (permalink)
TorinoStyle2
How about the CFE "Pro King" SBF race heads??
TorinoStyle2 is offline   Reply With Quote
07-26-2008, 04:49 PM   #8 (permalink)
tonys10sec306
canfield 230cc 18* race head would be a another great heads.if you can get your hands on a set i would grab them
[img]http://www.fordmuscle.com/readerscars/showpic.php?id=371[/img]
414 stroked heads upgrade dkstuck Stroker Engines 15 03-24-2006 06:55 AM
stroked 351W efi for \'68 Lincoln Cont. 4 door greasemonkey56 Late Model EFI Techboard 8 03-13-2006 05:43 AM
real427 or stroked 351W to 427 chris460c6 All Ford Techboard 5 08-07-2005 03:53 PM
408 stroked 351W ???? daffylong Stroker Engines 6 06-27-2005 03:54 PM
351w stroked to a 393 magoo Late Model EFI Techboard 1 11-22-2004 12:17 AM
