07-22-2008, 04:58 PM   #1 (permalink)
skyy
step up my 393
I have a 393 ci 11.3 to 1 compression, edelbrock vic junior heads and intake , custom solid flat tappet cam and a biggs hp 880 cfm carb
i want to step up, i was thinking world block, around 450 or so ci, with the same top end for now, ( other than the cam )
or cnc porting on top end heads, intake and do a solid roller cam , i dont know what the porting would cost or who to have do it does has anyone tried this? and what kind of gains can i expect?
skyy is offline   Reply With Quote
07-22-2008, 05:27 PM   #2 (permalink)
dennis111
Re: step up my 393
I can tell you that the a 450ci will be a performance dog with Vic Jr heads and intake. The proper heads to make such a monster work well will be $3500 or more.
What are your goals? Are you building a street or strip car?
Your second option has lots of potential. The Vic Jr heads can be ported to work very well, or a different head could be swapped on that might work better. I would figure $800-1000 for a good port (not hack) job from a knowledgeable porter.
Dennis
11.25@122.19mph
07-22-2008, 08:59 PM   #3 (permalink)
skyy
Re: step up my 393
street and strip
07-23-2008, 08:08 AM   #4 (permalink)
mrtbolt64
Re: step up my 393
Nitrous
1992 mustang lx coupe, caged, mini tubbed, 393 with Novi2k supercharger 11lbs of boost, BS3 EFI on 93 octane. 9.47 @144
1997 F350 psd 4x4 http://media.putfile.com/Mustang-Novi2k
mrtbolt64 is offline   Reply With Quote
07-23-2008, 04:07 PM   #5 (permalink)
skyy
Re: step up my 393
got it
Step by Step Rust Repair iryshman Tech Exchange 9 08-15-2008 06:59 AM
MSD Two step or Three step? frdnut Drag Racing 3 06-08-2008 11:09 AM
One step closer to a T-5! Eldoon The Garage 1 08-15-2005 07:27 AM
2 STEP? 1970DRAGSTANG All Ford Techboard 4 01-28-2004 07:25 PM
msd 2-step help rj All Ford Techboard 1 04-28-2002 11:17 AM
