Originally Posted by dfree383
Depends on your clearances, what did you set your motor up at?
What type / Weight of oil do you intend to run?
I don't know the clearances since I did not build the bottom end, but I am using Mobile 1 synthetic 10W30.
The reason I brought this issue up is because my rear main seal has now started leaking pretty bad. Before that, one of my valve cover gaskets pushed out. I still have the old factory oil pressure gauge so I don't know the exact psi, but it runs nearly "pegged out" much of the time. I've read where guys use standard volume pumps even with deep oil pans which made me wonder if my high volume pump is overkill and may be making a little
too much pressure. I will be dropping the oil pan to take care of the rear main seal and figured this would be the time to change the pump if it would help.
'67 Mustang Coupe
424W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Comp Cams hyd roller.236/.242 .555/.576-Miller rockers-Hooker Super Comps-3" exhaust-Gene Hughes AOD-3.55 Posi-4 wheel disc brakes
