I know what you're saying, but a Dart block
might cure the issue. What I'm saying is that you have a distortion problem. The block hasn't split, so it's strong enough
that way. If you can isolate the root of your distortion problem (perhaps just the det), you can likely run a stock block indefinitely at your power level. Or, maybe not - I don't know how close you are to ripping that puppy apart.
You may want to consider (assuming a good tune, no det like it shows, and no pre-ig) that a partial block fill, the best studs or 4-bolt 2-3-4 mains, or keyed caps, and a valley girdle, or, or... could keep you running hard. Unless you're running over 550ish HP, you should be able to make it live. Over 600 at 6000+ is on borrowed time even with the best tune. Boosted power is much easier on a block than NA power - if done well. Even a Dart block won't hold any pre-ig or extended det.
Didn't you lose a top land on this one? If so, the det that overheated and seized the top ring and spalled your bearings may also be your only gremlin. If that's all it was then you're probably good to go with a better complete tune. The Dart sure is nice, though...
David
