Re: Main Cap Girdle?
First of all, the way I understand it a stud girdle will not prevent an overpowered 302 block from splitting. They split in the webbing not from the main caps. I haven't heard of 351W's having this same problem especially the early, high-nickel blocks.
However just to offer a different view point, it just seems logical to me that tying all of the main caps together with a girdle will provide more strength and stability to the main caps and bearings. Its the same principle that applies to basic construction. Four walls are stronger and more stable once you install the roof beams. I installed a Canton set up in mine that is a windage tray/stud girdle combo, and a number of the engine builders I have spoken to still recommend a main girdle in high HP strokers.
Although, the thing you have to remember is that strengthening the mains will not prevent failures in other parts of the engine not related to the mains (such as the 302 webbing split). I think some people install one thinking that it makes everything bullet-proof.
Just my 2 cents.
 '67 Mustang coupe
425W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Joe Sherman spec'd Comp Cams HR -Miller rockers-Hooker Super Comps-3" exhaust-Gene Hughes AOD-3.55 Posi-4wheel disc brakes- 423RWHP @5600/ 448RWTQ @4400
