10-05-2009, 08:16 PM   #1 (permalink)
majorownage
Cleveland Stroker Build
Hey guys, I was wanting you opinion on this build I have.
351 Cleveland Block bored 020 over (deck height of 9.213)
AFD heads (4V version) (64cc chamber)
Small Block Ford Cylinder Heads
^^^Scroll down for the second chart of flow numbers.
Eagle cast Steel stroker crank (3.850'')
Scat forged chevy 5.850 rods
Sportsman racing forged aluminum pistons flat top, two valve reliefs (1.425'')
+5cc of dish
victor intake
850 cfm holley
and a .0210 copper gasket to give me a total of 0.033 inches between the piston and the cylinder head.
11.5:1 compression ratio w/ quench area =D
390 ci
How is this build and what cam to run?
majorownage is offline   Reply With Quote
10-07-2009, 01:03 AM   #2 (permalink)
BrianS
Re: Cleveland Stroker Build
Is the crank designed for the counterweights to clear the pistons using rods that short?
Sportsman Racing pistons? Have a part number?
What Victor intake?
Why are you using a copper head gasket?
What kind of cam...hydraulic, solid, roller...?
What else can you tell us? Vehicle, type of use, what trans, stall speed, rear axle ratio...?
[SIGPIC][/SIGPIC]Yahoo 351C Forum Owner
BrianS is offline   Reply With Quote
408 Cleveland build mtdewcowboy Stroker Engines 12 05-18-2009 09:15 AM
Cleveland Build (...Mr. Cleveland post) slik All Ford Techboard 55 12-16-2007 02:23 PM
Cleveland Build (...Mr. Cleveland post) slik All Ford Techboard 2 12-09-2007 10:31 AM
351 Cleveland Build vs 351 Windsor Build?? Polar68 All Ford Techboard 33 08-12-2007 11:35 PM
Cleveland 2V build cantedvlv All Ford Techboard 3 05-19-2003 03:54 AM
