10-14-2009, 02:30 PM   #1 (permalink)
hgufrin
408W Harmonic Balancer/Dampener
[SIZE=3]Hi All,[/SIZE]
[SIZE=3]408W, 500HP, Electric fan, Edelbrock Victor Jr. water pump, Alternator, No A/C, No Power Steering, External Balance…[/SIZE]
[SIZE=3]What balancer should I use? I ask because apparently I need that information before I order some aluminum pulleys from March Performance. Their catalog is asking whether I have a 4 bolt balancer or not???[/SIZE]
[SIZE=3]What do you guys have? SFI, Fluidampr??? 28 oz.?[/SIZE]
[SIZE=3]Thanks[/SIZE]
hgufrin is offline   Reply With Quote
10-15-2009, 08:44 PM   #2 (permalink)
doug351
Re: 408W Harmonic Balancer/Dampener
The imbalance should be matched to your crank. It should have been balanced with the rotating assembly or the rotating assembly balanced to a certain imbalance which could be 28 oz., 50oz, or 0 (internal). SBF balancers were 3 bolt in the early years and went to 4 bolt later. Anything 80's or up is going to be 4 bolt. Most aftermarket balancers have a bunch of holes so you can use either.
SFI means that the external balance ring cannot separate from the internal one. Which one to use is up to your wallet and preference, you will get many different opinions on which is best.
doug351 is offline   Reply With Quote
harmonic balancer?!?! etp20 Galaxie Pages 3 01-30-2009 09:27 AM
What harmonic balancer do i get?? saleenstang88 All Ford Techboard 2 05-25-2007 03:57 PM
what harmonic balancer trukstopcowboy All Ford Techboard 4 03-06-2004 04:15 PM
harmonic dampener on a 351C ? zICRONIx All Ford Techboard 1 07-21-2003 05:00 AM
harmonic dampener install dragman64 All Ford Techboard 14 01-12-2002 12:14 PM
Probe Industries
