10-15-2009, 11:50 AM   #1 (permalink)
L n L
Big Joe - rod/stroke b.s.
Big Joe - "As long as the rod is 2.00 inches or more longer than the stroke, NOTHING GOOD will happen. The rod to stroke ratio is pretty much all BS."
Joe, to clarify, are you saying that the rod should be at least 2" longer than the stroke, or not more than 2"?
I've had some debates with some friends on this, and would love to have your thoughts.
From my observations, it has seemed to me that when you can run as high an octane level as you want, that a longer rod may have a little benefit.
But, with octane level limited (like in the Engine Masters competitions in Popular HotRodding), a shorter rod may help keep a motor out of detonation.
Thanks,
Lee Atkinson
65 Factory Five Cobra, 302 efi, t-5, 12.5 @106
'03 Excursion 4x4, 6.0
'69 Falcon Station Wagon, 425W, 4R70W, 3.50, 11.51 @ 117.3, 3790# race weight
10-15-2009, 02:05 PM   #2 (permalink)
BIGJOE
Re: Big Joe - rod/stroke b.s.
That two inch thing is a real generalization. What I am really saying, the rod ratio is VERY UNIMPORTANT-- I used to build all kinds of differant rod lengths, and after several years, I could not remember which engine had which rod length,. They all seemed to run about the same. I remember back in 1990 ( Whatever ) I did a rod length buildup with Hot Rod magazine. The storter rod beat out the longer rod and boy did I ever get a lot of fan mail about that. Now days, I just put together what is easy to find and convient. I do use the longer as opposed to the shorter, maily because I like the lighter PISTONS-- I do lots of 383 Chevy engines, and one time I used the 5.70 rod because they were out of stock on the longer 6.0 rods, anyway, that engine was much WEAKER than any of the 383 Chevys I made with the 6 inch rods.. Something to think about. The rod length is important when you want to be able to rev the engine way up past the true HP peak (8000 and up )
JOE SHERMAN RACING ENGINES
10-15-2009, 02:48 PM   #3 (permalink)
L n L
Joe,
Thank you, sir!
Lee
10-31-2009, 10:08 AM   #4 (permalink)
DanH
the big benny of a longer rod in strokers is it keeps more piston up the bore at BDC , next is on restricted carb engines
10-31-2009, 10:27 AM   #5 (permalink)
Does keeping more piston up for longer cause the burn to occur for a longer duration thus effectively increasing the power of the burn? Is that the theory there?
Or is it all about the swing of the crank?
Honor!
11-01-2009, 08:10 AM   #6 (permalink)
ford4v429
my speculations on why longer rods might hold a advantage:
* trivia: only engines over 400 cubes with rod/stroke of over 1.8:1 were the 426 mopar and 429 Ford...hmm, both had tons of potential, and were built for sitting at 7k all day in NASCAR, back when NASCAR was driving almost production vehicles. think there might be something to that coincidence?
longer rods reduce piston scuffing sideforces compared to shorter
longer rods increase amount of crank rotation at the few degrees top of stroke- possibly 'cushioning' compression speed slightly to possibly cut down on preignition a bit, and piston sits there a tad longer at TDC to build more pressure
softening acceleration at TDC/BDC would have to mean reduced force on things like wristpins- would likely mean increased durability att high rpm.
mostly though, pushing straight perpendicular to the crank at 90 degrees would be best- longer rods help with that...as a sidenote, read the police/CJ 429 had piston pins offset like 1/16 clockwise to further straighten the rod out on the power stroke...do todays engine builders do this 'all the time' now? I dunno, I just read
To be fair/ on the flipside: shorter rods approach tangential angles to the crank sooner(at higher cylinder pressures), so can build more torque(even if piston sideload far increased) so powerwise, long rod *might* hurt torque numbers at lower RPM.
not trying to start any arguements either way, but would like to hear counterpoints for thinking either way...always heard 'best is around 1.75:1' but never heard actually WHY, and moreso wondered why the 426/429 did so darn well with longer rods- something just tells me its not a coincidence, but would love to hear everyones thoughts either way
Tim
Confidence: that feeling you have just before you realize the mess you've gotten yourself into...
http://www.fordmuscle.com/forums/galaxie-pages/490496-saving-65-galaxie-loooong-story.html
ford4v429 is offline   Reply With Quote
11-01-2009, 08:43 AM   #7 (permalink)
DanH
F 4V429 , got a few things backwards - one longer rods hit BTC for a shorter time . think of time , you only got so much , so things happen at different rates during the cycle .
11-01-2009, 09:14 AM   #8 (permalink)
ford4v429
just drew up to doublecheck...3inch stroke with 6 inch rod takes 18.84 degrees of crank to move .100
5 inch rod takes 18.47 degrees crank to drop .100
so at the same RPM the longer rod takes more rotation=more time at TDC/BDC= less shock to wristpins etc...the difference is less than I thought it would be, but still longer= softer unless the CAD is lying to me
edit...I'd checked top of stroke for above numbers- rechecked at bottom of stroke and different- Danh is correct, as he was talking BDC/I was thinking TDC(and I was assuming the crank angles were same top and bottom which they arent) the longer rod accelerates piston faster at the bdc reversal by quite a bit larger amount- 22.1 for the long rod, 22.9 degrees on the crank for the short rod, at the same .100 piston movement... looking at it again I see that up top the arc of the rod is opposite the arc of the crank, where at the bottom the arcs are on the same side of the circle- hadnt thought about that one...interesting...
11-01-2009, 10:32 AM   #9 (permalink)
Thanks for this stuff guy's, keep it up!
Honor!
11-01-2009, 10:28 PM   #10 (permalink)
ford4v429
in the numbers crunching/bench racing just got to wondering someting else...
What if instead of using offset wristpin holes, the cylinder bore centerline were offset instead, allowing pins on center to minimize piston wear, yet still achieve straighter rod angles on the power stroke?
just wondering aloud thinking of all the aftermarket blocks out there if one was ever cast for offsetting the banks for centered pins...would be a tricky part to machine, and would probably take a funky intake manifold, but just wondering...seems like the mains could be shifted around and then adjust deck accordingly, only issues then would be valve notches possibly...and bellhousing would need enough material for the tranny being offset then...hmm, maybe not, but still- just for the sake of arguement...
To stroke or not.... truedog All Ford Techboard 13 11-16-2006 10:20 AM
Anyone stroke an FE? gbeeler Stroker Engines 5 04-12-2006 08:09 AM
Could you stroke a .60 over 351 w bozz74 Stroker Engines 7 12-28-2004 02:21 AM
557 Stroke Kit 69Mach472 All Ford Techboard 1 08-24-2004 03:13 PM
289-302 Stroke HitmanKB All Ford Techboard 8 06-01-2002 02:27 AM
