Originally Posted by johny
This coming spring i will be starting an engine build strictly for drag racing.
Base block:351 winsor-1969 factory.
Heads: cleavland 4v- am planning on porting the exhaust side(just to smooth the exit)
Rotating Assy: All forged.
Compression: 13.5-13.7 (going to run e85 fuel)
Injection: will be using electronic fuel injection (megasquirt!!!!)
Throttle Body: 1375cfm (FAST technologies)
Cam: ????????? Thinking about a custom grind somewhere around a high .600, or low .700 lift. not really sure of duration yet.
Looking for some creative criticism....Ideas???? comments?????
Looking for around 750hp, maybe more????????
Megasquirt has been a pain in the @ss for the two people I know that have tried it. One is a mechanical engineer, the other is a PE with a computer science degree. The volumetric tables are what both have had issues with.
At F/M we have seen the desire for 600-750hp often. It's possible but a dream for most of us. It just isn't that easy or cheap. I'm guessing most that throw those numbers out don't even realize what 400hp is capable of.
We have a budget Fox with a budget 351W that has run a best of 11.38 and that scares me. I doubt the thing has any more than 400HP. I can't even imagine 750hp especially in anything with less than a very well pro prepped chassis.
I'm not one to "rain on someones parade" but hang around for a while, you will learn a lot.
Hint:
When Joe Sherman speaks, I generally listen even when he seems like he's just being a grumpy old fart.
