Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Suspension Articles
01-07-2009, 07:23 AM   #1 (permalink)
cramer
Lowering Block Kit Installation
After getting my suspension together I noticed that my rear end sat an inch higher then the front so I decided to fix it.
I chose a lowering kit since my leaf springs were in good shape and could not afford to get different ones.
I purchased the kit for around $25.00 at Autozone, a local auto parts store.
To do the installation I needed to do a couple of things.
1) Put a jack under the pumpkin and proceeded to remove the nuts from the U bolts and rear shocks.
2) After removing the nuts I proceeded to remove the plate that the shocks and U bolts attach to.
3) Remove the U bolts being careful that the pumpkin doesn't move around a lot.
4) Added the blocks into position and discovered that the new U bolts that came with the kit would not fit into the attaching plate.
5) Since my original ones were not long enough once I added the blocks and no one had any in stock locally I ended up going to the local junkyard, Pick-n-Pull.
6) Proceeded to get 2 sets, $2.50 each, from a 1994 or 1997 Ford Ranger since the dimensions were the same as my original but they were longer.
7) Cleaned up and installed the U bolts, attaching plate and shocks and tightened everything up.
8) Trimmed the U bolts using a grinder with a cut off wheel since they were longer then the original ones.
9) Let the car settle and measured and we were level with the front, so it worked...
These are pictures of the rear driver side before the lowering block installation
These are pictures of the rear driver side after the lowering block installation
Tools I Used:
* Wrench/Socket Set
* Grinder
* Jack
Estimated Cost (no discounts applied)
* Lowering Kit: 25.00
* U Bolts: 10.00 (4 * 2.50)
Total Cost: $35.00
Disclaimer:
I do not claim that this is the best way to do this, or even if you should do this, but rather that this is what I have done. Your cost, results and satisfaction may vary.
[/font]
cramer is offline   Reply With Quote
01-07-2009, 10:35 PM   #2 (permalink)
vertible59
Re: Lowering Block Kit Installation
Thought That Sucky Deal With The U Bolts Only Happened To Me!
vertible59 is offline   Reply With Quote
01-08-2009, 06:40 PM   #3 (permalink)
rmousir
I am glad you could find the kit at AutoZone. My local Autozone did not have that fit my axle. Got my kit from NPD.
Richard
1966 Mustang Coupe
\'95 roller 302, auto
warmed up just a little
check out my site: http://budgetrestomod.weebly.com/index.html
rmousir is offline   Reply With Quote
01-08-2009, 11:07 PM   #4 (permalink)
Cooon
Can I ask what the pumpkin is? Just never herd that term before.
Show us ya Falcon
Cooon is offline   Reply With Quote
01-09-2009, 06:14 AM   #5 (permalink)
cramer
Hello,
I was referring to the rear differential.
The round part where the drive shaft connects, which is kinda shaped like a pumpkin. It's one of those terms that I picked up somewhere and ended up adding to my car part vocabulary .
Marc Cramer
01-10-2009, 08:48 PM   #6 (permalink)
trashline
i got pretty lucky I only needed 3/4" when I installed/made my lowering blocks. and my caltrac U bolts had just enough on them to make them fit. Good info on the ranger U bolts though I will save that for a rainy day.
BCP Custom -> the new budget minded custom parts website
01-11-2009, 05:52 AM   #7 (permalink)
dennis111
BTW, NAPA sells several different diameter U-bolts and they often come in longer than stock passenger car lengths. Less than $10 each.
Dennis
11.21@124.0 al naturale
My Racing Videos
01-12-2009, 02:34 AM   #8 (permalink)
kuumakyyticom
Does stock shocks work with lowering blocks ???
1964 Ford Galaxie 500 XL ragtop
http://www.cardomain.com/ride/2192552
http://www.kuumakyyti.com/ragtop64
Any extra rockauto magnets, ANYONE ???
kuumakyyticom is offline   Reply With Quote
01-13-2009, 07:02 AM   #9 (permalink)
cramer
Hello,
They should.
I have a pair of standard replacement shocks on mine and no problems.
Marc Cramer
04-09-2009, 08:15 AM   #10 (permalink)
kuumakyyticom
Today I installed MooN 2" Drop block to driver side, even U-Bolt were ok for my galaxie !
HTML code is On
Lowering 63 Galaxie_dream Galaxie Pages 4 11-30-2008 04:01 AM
Lowering frt end Thad Truck Forum 3 01-12-2006 07:31 AM
Lowering \'02 Gt lg57 Late Model EFI Techboard 1 07-22-2003 02:53 PM
lowering dave65FB All Ford Techboard 7 08-02-2002 12:27 AM
