Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Suspension Articles
05-09-2009, 08:50 AM   #11 (permalink)
trashline
Re: Fox Thunderbird Rear Control Arm Upgrade and Pinion Angle Check
Originally Posted by bassman97 View Post
The latter ones went to IRS, maybe the 88+ is IRS? I'm not really an expert on T-Birds but I know they switched to IRS after the Fox platform.
88s were not IRS. Coil springs with the 4 link kinda rear. Upper and lower control arms. They used a straight axle 8.8 with either 3.55 or 3.73 gears, depending on trans. Im only speaking for turbo coupes here but Im sure the other models used a standard rear for that year. in 89 they changed over to the different body style and started running v6s with superchargers.
BCP Custom -> the new budget minded custom parts website
07-13-2009, 01:51 PM   #12 (permalink)
83-88T-Bird Gu
Nice article.
I am glad to hear that the Lakewoods only moved the rear forward 1/4 inch.
If someone uses a Southside type lower bar (commonly refered to as "lift bars") from a Mustang on a Fox T-Bird, it lowers the attachment bolt centerline further away from the centerline of the axle. This geometry in conjuction with a Mustang shorter control arm has the effect of moving the rear forward more than say the 1/4 to 3/8 inch difference in arm length.
I have owned over 24 of the 83-88 T-Birds and all of the lower arms are the same length including 87-88 Turbo Coupes. (of which I have owned 17 of those)
The pic above with the TRX wheels is my 87 TC with Southsides and yes I measured before and after and the Southsides moved the rear forward exactly 1.0 inch. Did the same thing on our 83 460 Gray Bird as seen in the pic.
Just informing of my experiences.
Also, we run our T-Birds pinion angle at 2 degree down as well....
83 T-Bird 460
83 T-Bird 5.0 RHO Heritage
84 T-Bird 302
87 T-Bird Turbo Coupe 460
87 T-Bird Turbo Coupe 2.3T
95 Mustang GT
83-88T-Bird Gu is offline   Reply With Quote
07-13-2009, 01:58 PM   #13 (permalink)
83-88T-Bird Gu
Here is a couple of pics of the Birds after I "fixed" the problem with a little streching of the Southsides:
83 T-Bird 460
84 T-Bird 302
95 Mustang GT
HTML code is On
pinion angle etp20 Galaxie Pages 3 04-01-2009 08:23 PM
Pinion angle Helmantel All Ford Techboard 4 08-24-2004 02:02 PM
pinion angle oldstangs All Ford Techboard 8 05-09-2004 11:29 PM
Pinion angle oldstangs All Ford Techboard 2 02-17-2004 09:29 AM
Pinion Angle ? PONY1 All Ford Techboard 4 05-31-2002 10:18 AM
