Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Suspension Articles
09-14-2009, 09:56 PM   #1 (permalink)
rmousir
Under Ride Traction Bars Install
Ever since I got my mustang I have wanted to get some of these. I have read lots of positive reviews and some negative review on these but hey they look cool. If Shelby thought they helped then maybe they really do. I will soon find out.
Just a fyi on cost for this project. I had all the materials I needed already. I already had the longer U bolts due to having lowering blocks. I got the traction bars in trade for a set of roller perches which I made for nothing. So for me and the math I am doing, cost = $0.00!! SWEET
Alright, I jacked up the car and put jack stands underneath the sub frames so there is no weight under the rear end. Then following 'safe steps' I backed up the nuts holding the U bolts that hold the rear end in place on the leaf springs. Added the plate that comes with the traction bars and then tighten up things to the proper torque. Then I put the car back down on all 4 wheels. I allowed the car to settle for some time before I moved on. I also drove it a few times. Not sure this is needed but I figured I was in no rush.
I believe that when this was done originally in the 60's the 2nd mount of the traction bar was welded to the sub frame. This is about where I should weld them in. (see in red) I was not sure I really wanted to weld these in place so I was stumped.
Above is the end that should be weld in place. Welding it makes it 'forever'. If by chance I didn't like these I wanted to be able to remove them
Basically the mount gets welded to the frame rail and holds things in place when you want traction. I saw a post on a forum some time ago that someone had welded or mounted there traction bars to there sub-frame connectors. I figured I could do the same thing. Make up some brackets and use some high end bolts to keep it all together. Should work I think. So this is how I did it.
So I managed to get some 2" angle iron from a neighbor. The traction bar mount is 4" long so I cut a 6.5" piece. I then fit it in place on the sub-frame connector and over the frame rail that the mount would weld to.
I found that I had to notch the angle iron to get a snug fit to the sub-frame connector. I also found that the angle iron wouldn't cover the frame rail the mount would weld to. It was short by about a 1" or so.
To fix this I used some flat 2" iron and drilled some holes in it and welded it in place (FYI, the holes are for plug welds, makes it much stronger). I welded up all the edges to make sure this bracket was going to cut the mustard! This started to look like something that might work. I always measured 2 or three times before I cut or welded.
Once I was finished that I used a clamp and held the back in place where I would need it to be and drilled out 2 holes that went through the bracket and through the sub-frame connectors. This allowed me to use my grade 8 1/2 bolts with lock washers to hold the bracket in place for the next step.
With the bracket in place on the sub-frame connector you can see how the top of the bracket covers the frame rail where I am going to weld the mount for the traction bars.
So far so good!
(pictures above are from drivers side).
I then put the bar in place. i snugly secured the end of the bar that would go in the bracket that is under the rear end and then put the mount in place. I then clamped it in place on the bracket so I had things square and correct. (FYI the car is sitting on its tires for this install).
Now it was time to put a couple of spot welds on to hold things together. I removed the bracket and welded everything up solid. Allowed to cool and painted. [/SIZE][/font]
( picture above are drivers side)[/SIZE][/font]
This is how things looked when I removed the bracket after doing a couple of spot welds to keep things in place.
(above picture is passenger side bracket show)
One thing I did, and I am glad I did, was leave the bolts that secure the bracket to the sub-frame connector in the bracket. The bolt behind the mount won't come out because it will hit the mount bolt. Next time I might move the bolt a 1" or so to the side to avoid this. Not sure it is really a problem though.
I used a wire wheel to clean things up really nice and then gave the brackets a shot of Rustoleum. Once the paint was dry it was time for final assembly.
Final installation is pretty basic. Put the bars in the mount bracket and in the spring bracket. Install the bolts that came with the bars, everything should line up perfect if you did a good job. Tighten up plus 1/4 turn, not to over tighten. This should really help at the track. I will find out in the spring. Enjoy!
Richard
1966 Mustang Coupe
\'95 roller 302, auto
warmed up just a little
check out my site: http://budgetrestomod.weebly.com/index.html
rmousir is offline   Reply With Quote
09-15-2009, 08:24 PM   #2 (permalink)
pass1over
Re: Under Ride Traction Bars Install
nice job
I didnt care for the grade 5 hardware on the bars, so I replaced them with G8 stuff.
Also didnt care for 1 side of the front being unsupported. I did some research and found that the original shelby ones had a bracket on both sides of the bar where it attaches to the frame. Had a pair custom made by a friend at a steel place, might not need it, but it helps me sleep better at night.
'08 Infiniti G37S daily driver
stroked EFI '66 Mustang weekend fun
pass1over is offline   Reply With Quote
09-15-2009, 08:34 PM   #3 (permalink)
rmousir
having a bracket on both sides of the front mount is a great idea. I might just have to add that. It wouldn't be hard to do at all since I can easily remove my mount brackets!!
Richard
1966 Mustang Coupe
09-16-2009, 05:39 PM   #4 (permalink)
ford88
I have a set for my 66 fairlane,I seen some guys running in the 11s with stick cars and no Issues with the single mount on front.Also the same company is still making them.
ford88 is offline   Reply With Quote
09-17-2009, 07:35 AM   #5 (permalink)
L n L
After everything was purchased, how much money did you save over just buying the adjustable Cal-Trac system?
65 F5 Cobra, 5.0, t-5, 12.5 @106
'69 Falcon Station Wagon, 425W, 4R70W, 3.50, 11.51 @ 117.3 (waiting on rollbar!), 3790# race weight (Feb. 2010 issue of Popular HotRodding, pp.32-37)
09-17-2009, 07:50 AM   #6 (permalink)
rmousir
I have never priced out the cal-tracs. For the cost of this project:
When I made my roller perches, I ended up having 3 sets of donor perches so I spent the extra money to rebuild all of them. So my cost was a kit from Daze ($30 maybe). Then when they were done I traded a set of those for these. These were brand new.
The angle iron I used was donated from a neighbor across the street and I had the rest of the materials.
Add about $8 for the bolts and I was done. So all total I estimate that it was less than $40 and my time.
Richard
1966 Mustang Coupe
09-17-2009, 12:42 PM   #7 (permalink)
pass1over
awesome! thats movin
like I said, it might not be necessary, but it makes me feel better to have both sides supported, and with a G8 bolt.
HTML code is On
Under-ride Traction bars pass1over Mustang Pages (1965-1973) 5 03-25-2009 05:06 PM
slapper bars /traction bars elsanyo Truck Forum 0 08-18-2008 06:43 PM
Shelby under ride traction bars MUSTANG66 All Ford Techboard 14 06-15-2004 02:42 PM
Traction Master 1966 Shelby Style Traction Bars? GregS All Ford Techboard 17 01-26-2004 10:01 AM
Probe Industries
