07-16-2007, 05:35 PM   #1 (permalink)
Ranchero65
Grafting Shelby GT Scoop on 1965 Ranchero Hood
I wanted a hood scoop on the spare hood that I had for my 1965 Ranchero. I finally decided on a Shelby GT scoop. With detailed instructions from www.autobodystore.com forums written by Len Stuart, the owner of the site, I proceeded as follows.
Pictures read from left to right.
Picture 1
Take the scoop and place it in the desired position and draw its outline on the hood.
Picture 2
For a functional scoop, cut the metal so that you have a couple of inches under the edge of the scoop.
Picture 3
Drill some 1/8" holes in the scoop through to the hood about every inch and insert a screw to pull the scoop down. Doing this type of mounting on other areas of the vehicle and you may be able to clamp the panels together.
Picture 4
After the holes are drilled and the screws are in place, remove the screws and the scoop. Grind the metal clean near the point of contact as well as the glass using a 16 or 24 grit disk.
Picture 5
Apply your bonding material (I've been using Dyna-Weld) To both surfaces pushing the material into the scratches then build up a little on the surface and put the two pieces together and screw it down. DON'T screw it down tight because the Dyna-Weld is your glue and if you squeeze it all out your scoop will pop right off. Just pull the scoop down enough so that the paste starts to push out of the crack a little.
Picture 6
Since the Dyna-Weld was a one-to-one mix ratio product, I felt it was best for me to get 2 matching caulking guns to use. A number strip also comes with the Dyna-Weld kit that you apply to the plunger handle of the caulking gun to get a more accurate dispensing of the materials.
Picture 7
After the material gets hard remove the screws and grind off the excess bonding material and do some initial shaping with the grinder. Countersink the screw holes and cut a strip of fiberglass cloth about an inch wide to cover the seam all the way around the outside of the scoop.
Using more Dyna-Weld apply it to the edge filling the screw holes and giving you some buildup over the seam then push the fiberglass cloth into the soft paste so that it covers the seam and apply more DW on top while everything is still soft. You may need to do about a foot at a time because this could take long enough for the DW to start to harden. So cut the cloth strip into 1 foot lengths and do one at a time until you're all the way around and the cloth is buried in the DW and covering the seam.
Picture 8
Once the DW is hardened over the cloth use the appropriate sanding block to shape the filler. Apply more of the filler (you can now use flexible polyester putty) and continue the shaping but try not to sand so much off that you sand through the cloth reinforcing strip. Here are some of the tools I used for the shaping and sanding of the material to create a smooth transition betweeen fiberglass and metal.
Pictures 9, 10, and 11
The idea here is to use a flexible material (Dyna-Weld and flexible putty like Poly-Flex) so that the different expanding/contracting characteristics of the materials won't cause cracking.
grafting-shelby-gt-scoop-1965-ranchero-hood-hood9.jpg grafting-shelby-gt-scoop-1965-ranchero-hood-hood10.jpg grafting-shelby-gt-scoop-1965-ranchero-hood-hood11.jpg
Pictures 12 and 13
When you have your shape sanded to where you're happy with 80 grit paper then go over it with some 180 and then spray it with some 2K primer using a flex additive so that the primer is also flexible. After guide coating and sanding the primer with some 400/600 grits sandpaper you can apply paint but be sure that the paint ALSO has flex additive added so that it won't crack. Pictured is the finished hood covered with Kirker Euro epoxy primer. I really like this primer and it is easy to sand when necessary.
grafting-shelby-gt-scoop-1965-ranchero-hood-hood12.jpg grafting-shelby-gt-scoop-1965-ranchero-hood-hood13.jpg
Picture 14
I deviated from the instructions above using materials I had on hand. The fillers I used were Evercoat's Rage Gold and UPC Icing. The picture below is the back side of the hood showing how I did not sacrifice the integrity of the original hood bracing. I'm hoping this will prevent the flexing issues that others have had. The color is the color that the Ranchero will be when finished. I hope my deviations from the original instructions won't come back to haunt me later.
Take Care
Earl - Ranchero_65 Restomod Slowley in Process !
www.ranchero65.com
Ranchero65 is offline   Reply With Quote
07-17-2007, 05:33 PM   #2 (permalink)
retyler
Re: Grafting Shelby GT Scoop on 1965 Ranchero Hood
Great work, scoop looks like it was made for it. Thanks
07-17-2007, 09:21 PM   #3 (permalink)
ChicoB
Man that looks great!
07-18-2007, 01:44 AM   #4 (permalink)
myfast5oh
Good Job !
myfast5oh is offline   Reply With Quote
07-18-2007, 04:12 AM   #5 (permalink)
KULTULZ
Thumbs up Re: Grafting Shelby GT Scoop on 1965 Ranchero Hood
Looks Nice!
[FONT=Century Gothic][/FONT]
07-18-2007, 11:15 AM   #6 (permalink)
jrosengarth
Do you have a seperate building you do body work in than where you do engine work? I want to be able to do more of this kind of stuff without turning my garage into one big dust bin.
Very nice work, BTW.
-J
http://www.concentricsoft.com/Personal/Jim/Truck/TruckRebuild420(sig).jpg
F150 Rebuild Project Website
jrosengarth is offline   Reply With Quote
07-18-2007, 06:49 PM   #7 (permalink)
Ranchero65
Thanks for the replies guys !
Jim, I only have one shop . Wish I had more but what I have now is better than what I have had in the past. Pic's of shop on my web sight.
Take Care
www.ranchero65.com
07-23-2007, 07:03 AM   #8 (permalink)
map351
Nice job!
Cobra Restorers, Ltd makes a stamped Aluminum hood scoop that might be eaiser to work with..
I also use (Fusor) Killer bonding!
Map
http://www.parts123.com/PartFrame.as...obra_Restorers
Hertz 6S1941 & 289 Slab Side Cobra
73 Turbo Pinto
1940 Sdean delivery<< For sale
map351 is offline   Reply With Quote
07-26-2007, 03:38 AM   #9 (permalink)
1965Comet
Very nice Earl...enjoy watching you work...
g
George
[url]www.1965comet.net[/url]
1965Comet is offline   Reply With Quote
HTML code is On
Hood Scoop mikemustang289 All Ford Techboard 13 06-04-2007 05:43 PM
Hood scoop? Matt All Ford Techboard 14 11-09-2006 06:43 AM
Hood Scoop Help? Lucky Fairlane Pages 2 11-02-2006 11:45 AM
Hood Scoop karguy Falcon Pages 10 03-10-2006 09:45 AM
what hood scoop looks.... fast67ford Galaxie Pages 5 06-06-2005 06:00 PM
Powerhouse products
