07-20-2007, 11:09 AM   #1 (permalink)
frdnut
Installing Aftermarket Gauges in 67-68 Mustang
My 68 mustang has a factory console so it pretty much eliminates using underdash gauges and there isn't really anywhere else to put them.I wanted a clean factory look but with the accuracy of aftermarket mechanical gauges so I decided to try to put them in the instrument panel myself..I bought a instrument cluster at a swap meet for $20 bucks and got busy...
First remove the instrument cluster from the dash and remove the plastic front bezels from the cluster.
Next I removed the plastic lenses from the bezels. I test fitted the 2 1/16 gauges in the bezel and they fit perfectly..When I tried to slip the metal retainer over the gauges from the back the opening was a little too small..I cut a small snip about every 1/2 inch along the opening of the retainer so I could bend the edge back enough to allow the gauge to slip through the retainer and screwed them down tight...
Do the same for all three.
Next, it became obvious the the two outside gauges were too deep to fit into the cluster without some modification..The center gauge where the optional clock was installed was empty on my car and had a large removable plastic piece that allowed the gauge to pass through perfectly.
The back part of the two outer gauges were cut out using a combination of a Dremel with a cut off wheel and some tin snips.It doesn't have to be pretty since it can't be seen from the front side anyway.Also don't worry about saving the factory light here since the guages have their own lights and are sealed up.
That is the toughest part of the swap and cannot be undone. Next I taped the factory wire connections up so they can't touch anything and kept them out of harms way..I used the factory instrument light wires at the ends of the cluster and wired them to the light bulbs in the guages.The autometer guages come with a little green cap you can put on the lightbulbs that match the factory bluish tint pretty well. Install it back in the dash and your done except for routing the lines to the engine compartment...You can buy the instrument cluster already done for you but they are very expensive.This way it will only cost you the price of the gauges themselves. Next on my list is doing the speedo and tach conversion or at least relocating my tach. The pictures don't do this swap justice as it looks very factory when done.
07-20-2007, 11:31 AM   #2 (permalink)
admin
Re: aftermarket gauges in 67-8 mustang
This is an excellent how-to!
admin is offline   Reply With Quote
08-29-2007, 04:34 PM   #3 (permalink)
thekingofazle
This was exactly how I did my '67.
Wesley
11-18-2007, 11:56 AM   #4 (permalink)
mstngfrdlvr
Re: Installing Aftermarket Gauges in 67-68 Mustang
This ROCKS!!! I just did my car, and this how-to was the best!!! You should do articles for some rag Willy.
68 Coupe
289
C4
3.55's/Trac-Lok
mstngfrdlvr is offline   Reply With Quote
11-18-2007, 06:05 PM   #5 (permalink)
frdnut
Thanks Coop.:
11-19-2007, 11:10 AM   #6 (permalink)
sharpshot71
Thats kinda what i want to do to my 73, how hard is it to hook an aftermarket speedo and fuel gauge up to the factory sending units?
Great Article
12-24-2007, 04:56 PM   #7 (permalink)
tubbie50
Hi nice job on the cluster could you tell me what gauges you used part # if possible . Merry Christmas
Jim
tubbie50 is offline   Reply With Quote
12-29-2007, 06:54 PM   #8 (permalink)
frdnut
Jim
Thank you....I used the sport comp 2 1/16 gauges by autometer..If you go to autometer.com you can view the lineup of their gauges..I used these ones simply because my local speed shop had them in stock..You can get a variety of different coloured bezels and faces to suit your taste....I originally tried to fit the bigger 2 5/8 guages but there was just too much cutting on the original plastic bezel to get them to fit for my taste.....I have seen some aftermarket rear supports for the guages but can't seem to find who carries them..This would save you having to cut up the original metal piece.
HTML code is On
putting aftermarket gauges in car need help on fuel level gauge choice 65289pony Mustang Pages (1965-1973) 2 10-12-2006 06:16 AM
Installing aftermarket heads, Am I getting ripped off? BLACK65FORDFALCON All Ford Techboard 26 09-26-2004 08:33 PM
Installing an Aftermarket CD player system in a 66 Mustang artaefakt The Garage 9 07-25-2003 03:28 PM
70 Mustang gauges cantedvlv All Ford Techboard 3 07-25-2003 04:38 AM
Where to mount gauges in a Mustang DesertSnake All Ford Techboard 6 10-31-2002 12:18 AM
