07-27-2007, 07:01 PM   #1 (permalink)
1bad6t
Pinned Motor Mounts
After separating a motor mount again I knew I needed something stronger than stock motor mounts. I didn't want the harshness of solid motor mounts on a street driven car the vibration from the engine will eventuality take its toll on other parts. This modification not only keeps the motor mounts in one piece, it will also put more torque to the driveshaft by eliminating the flex in the OEM mount that is lifting the engine when it is rev. It will make a more responsive drivetrain that will responds crisper to throttle response. You also gain less wheel hop, not to mention less chances of the headers hitting the shock towers due to the engine twisting. With this modification I can now have almost the smoothness of rubber mounts and the strength of solid. I can feel a very slight vibration with the mounts being pinned, but it is not enough to be concern it is something that was expected.
New Motor Mounts
__________________________________________________
Step #1
Drill 2- 25/64" holes in each mount.
Step #2
Counter sink the holes.
Step #3
Use 3/8"x 1 3/4" Stainless
Flat Head Cap Bolts.
Step #4
Using Loctite, tighten nut until the bolt
starts to spin, plus an extra 1/4 to 1/2 turn.
Step #5
Grind the bolt head flush with the mount,
then paint mount to deter rust.
Now you have a motor mount that is solid without the vibration.
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
07-27-2007, 09:31 PM   #2 (permalink)
Nitmare67
Re: Pinned Motor Mounts
Been doing this since high school. Works great.
Nitmare67 is offline   Reply With Quote
07-28-2007, 09:21 AM   #3 (permalink)
josepheblack
Thumbs up Re: Pinned Motor Mounts
Nicely done.
http://www.fordmuscle.com/pictures/j...k/IMG_0010.JPG
josepheblack is offline   Reply With Quote
07-29-2007, 05:39 AM   #4 (permalink)
FATNFAST
Good info, nice step by step. thanks for sharing.
Rick in Indy "408 Clevor" 10.185@128.76
08-08-2007, 09:04 PM   #5 (permalink)
rancheroo
Jeff, great article,
Rick
rancheroo is offline   Reply With Quote
HTML code is On
Motor mounts lgh1157 Galaxie Pages 3 10-28-2005 12:41 PM
Motor mounts for 460 into a \'68... Will \'69 429 mounts work? adgdghr123 Galaxie Pages 2 09-07-2005 08:38 PM
66 motor mounts in a 64 TALON Falcon Pages 0 06-10-2004 09:06 AM
FE Motor Mounts (pic) Effie All Ford Techboard 1 02-14-2003 12:04 PM
motor mounts RacinGator Falcon Pages 6 02-10-2003 08:58 PM
