08-11-2007, 04:26 PM   #1 (permalink)
Mikelonis
TuffHook Cargo Tie-Down System
by Jon Mikelonis
When the FordMuscle staff visited SEMA last year, this clever device caught my eye both for its' utility and sturdy construction. The TuffHook is the creation of Keith Dunlop, a powersports enthusiast who often wondered why even most modern trucks lack sufficient tie down points at the forward portion of the bed. The same issue is even more common with early trucks, like FordMuscle's Project Redneck that have plenty of tie down points outside the bed, but none inside the bed. While the primary concept of the TuffHook was to provide worry-free attatchment points to secure motorcycles, atv's, and bikes, the design is great for securing all kinds of bulky loads, even those typically encountered by automotive hobbyists like you and I (ie, large tires, transmissions, engines, fenders, etc.) FordMuscle can vouch for the TuffHook's quality universal design since it bolted right up to Project Redneck without the "flimsyness" that sometimes comes with "one-size-fits-all" parts.
Here's a pictorial showing how easy it was to install and a few "in-use" shots.
1. Using a spray adhesive, I got started by attaching the included Rubber Side Protectors to the outside of both the left and right Main Frames.
2. I secured the driver's side Main Frame with my "third hand".
3. Next, I inserted the Frame Center Inner into the driver's side Main Frame. Take note of the "Up" indication on the Frame Center Inner.
4. Using my "fourth-hand" I secured the passenger side Main Frame making sure it was inserted in to the Frame Center Inner.
5. With the threaded hole of the Frame Center Inner located midway between the Main Frame ends, I added the Rubber Center Protector and secured the Frame Center Outer with the large threaded eyelet.
6. Now it was time to mark the holes for attaching the TuffHook to the truck bed. There are eight attachment points.
7. The top of the front bed rail requires four holes, all must be drilled with a 31/64" bit.
8. While each Main Frame of the TuffHook can be attached to each siderail with two bolts, some beds will not allow the forward point to be used. The case was true with the 1978 Ford. However, it's not a problem since the install is plenty secure without them. The siderail holes were drilled with a 21/64" bit.
9. The TuffHook includes these Fast Nuts which allow you to install the Main Frames without reaching underneath the front bed rail.
10. The Fast Nuts require this included installation tool. This picture shows how you use the tool. However, I opted to forgo the Fast Nuts and used my own automotive grade hardware.
11. Now it was time to place the TuffHook back into position.
13. Here I am tightening one of the four included Cap Head Socket Screws. Again, I was patient and added an integrated washer and nut to the underside of the front bed rail.
13. The Main Frames are attached the the side rails with carriage bolts. This 78 Ford's bed design would not allow me to use the front mounting location. That's OK because it's plenty secure without them.
14. Here's an example of one of the adjustable eyelets and cotter pins.
15. If you are into motorcycles then this wheel chock will come in handy.
16. A final view of the TuffHook, it's surprisingly unobtrusive.
17. Here are some spare tires ready for delivery to a local craigslist shopper.
18. With the use of a ring I installed in the rear of the bed, the TuffHook helps secure this old Ford fender.
The TuffHook is produced by Proform Parts. Visit PROFORM® Engine Performance ©2006-2007 | Official Site for more product information including a list of official TuffHook dealers.
HTML code is On
Who has the best System? Strokin83 Falcon Pages 11 11-09-2006 07:27 PM
Is my fuel system adequate for a nitrous system? xrayengineer All Ford Techboard 4 03-28-2006 12:31 PM
Air System big1 The Garage 16 12-22-2004 11:09 PM
What cold air system/filter system for 2001 Cobra? ricanchulo373 All Ford Techboard 2 07-12-2004 11:58 PM
PCV system dave65FB All Ford Techboard 2 06-13-2002 07:08 PM
