10-01-2007, 04:41 PM   #1 (permalink)
Mikelonis
Stud Mounted Shop Bench
Since all of my spare parts and hardware were poorly were organized in my garage, I found myself disoriented when thinking about taking on my next big FM project (400 build). Years of hording small parts and swapping out old for new had made the left-hand side of my garage an ineffecient mess of bins and boxes. Everytime I needed to find something, I had to squat down like a caveman to find it. Sometimes, I even found myself making trips to the auto parts store or to the wrecking yard to buy something I knew I had. Why? Because at least at the wrecking yard and the auto parts store I could find what I needed while standing upright. Enough of that! So I busted out my wood tools. Here's what I did to solve the problem and please keep in mind I have no formal training in carpentry.
This was the problem situation. Tons of bins and boxes forcing me to squat down at the expense of my back to locate what parts I needed.
I took a trip to Home Depot for some 2"x4"s, 4"x4"'s, 2"x6"s, and some 1/2" plywood they had on sale. The plywood was cabinet grade, so it would make for a smooth surface for the top of my new bench.
I got started by screwing a 2"x6"x12' board to the studs at a nice comfortable height for someone my size.
My garage floor was not parallel to the foundation, so each 4"x4" leg needed to be a different height. Here I used a floor jack, a short 4x4, and a level to make sure the bench top would be parallel to the foundation and not with the garage floor.
Here's a close-up showing that I notched the 2"x6"x12' board to support 2"x4"s. I screwed the 2"x4"s into the 2"x6" and to the 4"x4" legs.
I tied the perimeter together with 2"x6"s.
I cut the plywood with a Skil Saw to fit. Each section was 2'x4'. I also added a shelf between the bench top and the floor using a 2"x4" to support the front of the shelf and the foundation to support the rear.
Next, it was time to build some storage shelves. Here I am doing a few miter cuts.
This is a shot of the shelf bracing. I used 2"x6" boards to support the rear of the shelves and 2"x4"s mounted to the studs at 45 degrees.
Yes, I was anxious to see how the whole thing worked even before I finished, so I started organizing my stuff. In this shot, I'm screwing down the shelf top.
I'm sure I violated a few basic carpentry basics but the shelf is very strong and extends 14" from the wall.
My brother and my sister-in-law dropped by over the weekend and were willing to help build more shelves on the other side of the bench using the same design.
Here's the whole thing done and successfully holding my stuff. A 12 foot work bench and storage space along with three 8 foot shelves.
NOW I could begin my next FM project. I pulled my neglected 72 Torino out of the side yard and pointed it towards the garage after I washed it down.
Here it is, an organized garage ready for a 400 build and the resurrection of a Torino.
10-02-2007, 02:18 PM   #2 (permalink)
morgan
Re: Stud Mounted Shop Bench
Looks good, but you forgot to inslulate the wall and had a few more needed electrical outlets and then cover the insulations and studs with wall board. (LOL)
Morgan
morgan is offline   Reply With Quote
10-03-2007, 07:51 AM   #3 (permalink)
Chiefe9
Looks good and should definitely meet your needs. You're a good man and thanks for all you do to make this site such a success!! The benefits of being a subscriber are worth every penny of the cost. Roy
[/SIGPIC]1967 Galaxie XL/390 C.I.-315 H.P./ 4barrel/4-speed/work in progress
Chiefe9 is offline   Reply With Quote
10-03-2007, 08:52 AM   #4 (permalink)
slepe67
you wouldnt HAPPEN to be a carpenter would you? Just kidding! Looks great, and gave me an idea on where to put my parts bin, and how to build around it. Great idea!
1967 Mustang T/A Coupe clone/resto
slepe67 is offline   Reply With Quote
10-18-2007, 11:36 PM   #5 (permalink)
CHICOY2K
How Much U Want For Your 72??
CHICOY2K is offline   Reply With Quote
01-19-2008, 12:29 AM   #6 (permalink)
jmcclesk
Where did you get the yellow parts bins at??? i have been looking for a set up like that and cant seem to find them.
jmcclesk is offline   Reply With Quote
01-19-2008, 01:04 AM   #7 (permalink)
Bumblebee
jmcclesk,
You can get those at Harbor Freight Tools - Quality Tools at the Lowest Prices or Portable Generators, Heaters + Wood Stoves, Snow Blowers, Pressure Washers | Northern Tool + Equipment
Great job on the workbench by the way Mikelonis..... is that an FM shirt I see in the pics????? nice product placement!!!
Keith/Bumble
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.Albert Einstein
Bumblebee is offline   Reply With Quote
01-26-2008, 12:49 AM   #8 (permalink)
jmcclesk
Thanks for the info. I found the parts at harbor freight and it was on SALE. BTY nice work bench.
02-27-2008, 08:30 PM   #9 (permalink)
porkchopious
You know, I forgot just how good those Torinos looked from the rear!
porkchopious is offline   Reply With Quote
02-27-2008, 10:22 PM   #10 (permalink)
165falcon
thats good stuff, I picked up some wood to do a bench of my own this weekend, might have to take some of your ideas. thanks
165falcon is offline   Reply With Quote
HTML code is On
I got Mounted, and Balanced Today Murff The Garage 9 07-31-2007 11:45 AM
My trunk mounted battery fordracerguy All Ford Techboard 2 04-08-2007 12:01 PM
Got my slicks..... where to get them mounted- gchero351 All Ford Techboard 16 02-21-2007 12:26 PM
275/50/15 tire, can it be mounted on a 10\" wide rim? Cman All Ford Techboard 4 06-06-2004 09:20 AM
Hood Mounted Tachs NoLongerHere All Ford Techboard 3 09-08-2003 02:26 AM
