11-13-2007, 04:11 PM   #1 (permalink)
frdnut
Mustang aluminium radiator upgrade
I recently swapped a 408 windsor stroker into my 68 mustang in place of the original 302....I was concerned that cooling the new engine might be a challenge since it would be over twice the horsepower of the original engine!....Luckily my car came with the heavy duty cooling package since it had air conditioning...The heavy duty cooling system is basically nothing more than a 3 core big block rad with the lower outlet on the passenger side to match the early small block water pump....I wasn't sure if I should replace the stock style rad with a 4 core unit or try swapping in a light wieght aluminum rad with supposedly superior cooling....After doing some price shopping the Northern Universal fit aluminium rad was well over $100 bucks cheaper and the dimensions sounded close to stock so I thought I would give it a try....The stock rad measured 21 X 25 3/8ths while the northern was 19 3/4 X 25 3/8ths....
The northern was advertised as a 19X26 so it was a bonus that it actually ended up being the exact same width as the stocker and not the full 26 inches as advertised...Room is tight here on an early mustang between the battery tray on one side and the voltage regulator and wiring on the other.
Now that it appeared it would fit in the car ok I had to figure out how to mount it...Again I was very lucky to have had the big block style rad in the car originally as it has similar style bottom mounts to most cross flow rads..These little mounts bolt to the A frame at the front of the car and can be easily added to normal small block cars whose radiators actually bolt to the front radiator support
I did have to modify the mounts a little since the thicker end tanks on the crossflow rad make contact against the rad support and make it sit towards the engine a little more than the stock rad..I simply removed the mounts and bent them flat and then rebent the ends back up giving me an extra 1/4 inch or so of flat length for the rad to sit on..The stock rubber insulators were now too short to fit back into the stretched mounts so I had to go to the local wrecking yard to find some that would fit....I robbed a pair of lower rubbers out of a mid 80s cadillac that were plenty wide...I applied some weather strip adhesive on them to help keep them in place and stuck them on the steel mounts....
Now it was time for the top mount which in my case is a clamp on type big block style mount that bolts into the front of the rad support along side the hood latch...It required the same widening treatment as the lower mounts since the stock rad actually narrows in on the top tank for the mount to fit into..It was a little harder to reshape the ends of the mounts but I managed to get it done with a vise and ball peen hammer.
I wasn't entirely happy with the overall look of the top mount but it was functional and used the stock parts..I did need a longer piece of rubber just like the lower mounts to span the extra gap..
The outlets on the nothern rad are the same size as the original and amazingly the stock 302 rad hoses fit perfectly even though I switched to the drivers side lower outlet for the 408....
So how does it work?....Well I have been very pleasantly surprised..With a 180 degree thermostat and an ancient clutch fan the engine runs right at 178 degrees even on extremely hot summer days...Sitting still in traffic on those very hot days will see the temp slowly climb to around 190.. I'm sure this would be easily fixed with a shroud which is on the "to do" list.. I am going to switch to an electric fan with a built in shroud in the future and probably fabricate a nicer looking upper mount like a later model mustang that would cover the whole top of the rad...
Update...I finally got around to changing my upper rad mount..I simply used two short pieces of threaded rod through the original holes in the rad cradle and into the top edge of the rad...I put a nut on each end and covered it with a piece of stainless steel...
11-14-2007, 03:24 AM   #2 (permalink)
dennis111
Re: Mustang aluminium radiator upgrade
Nice write-up and pics. I like that you can use the stock brackets, with a little hammer/vise action to install the crossflow in place of the original gravity feed radiator.
A couple of more articles and you can have a new hat that will match the new tee shirt. LOL
Dennis
11.52@121.29mph
11-14-2007, 06:34 AM   #3 (permalink)
blown68
If you don't mind going the pusher route on the electrics, I have found that twin electrics fit perfectly into the core support on a '68 from the front side of the radiator. It also gives you plenty of room betwwen the radiator and your motor. You can also mount them as pullers and they work great too, but I like the fact that they fit into the support so perfectly on the other side.
http://i226.photobucket.com/albums/d...own68/fans.jpg
Flex-a-lite twin electric
Flex-a-lite Low Profile Electric Fans: FLX-210 - summitracing.com
blown68 is offline   Reply With Quote
11-14-2007, 05:21 PM   #4 (permalink)
mrmustangman357
does anyone have a similar solution for 65-66 models?
mrmustangman357 is offline   Reply With Quote
11-14-2007, 06:02 PM   #5 (permalink)
n2omike
Hey frdnut,
Does that universal radiator have the crooked bottom outlet like most of the 'universal' aluminum radiators out there? Most companies put that crooked outlet on there to (I believe) screw things up for those of us wanting to do something similar as you.
Thanks!
And for the 65-66, a crossflow can be used, but mounts will have to be fabricated. It's not that big of a deal. It also helps to cut out the core opening a bit.. but it's not really required usually. Measure how wide of a crossflow unit will fit, then fabricate from there. A fairly common swap, actually.
Good Luck!
66 mustang
11-14-2007, 06:09 PM   #6 (permalink)
n2omike
Wow, this place has any size Northern Radiator for $169.95
Go there and search for "northern radiator" to show all the sizes.
TC Race Cars
66 mustang
11-14-2007, 07:14 PM   #7 (permalink)
dennis111
In a couple of afternoons I installed a 67-68 Mustang core support in my 65'. It requires some welding and body work skills as it is not a direct replacement, per se. The height and apron width are the same as constructed. There are some differences that require some metal removal and some that needs added in order to fill the gaps.
It will also require a battery tray mod which consists of a 67/68 battery tray and the support brace from a 65/66 if you want to keep the battery in the engine compartment. Another option is to use the 67/68 apron which mounts the battery horizontal in the engine compartment (instead of horizontal to the radiator support.)
Once the new support is installed, it would be easy to follow Frdnut's article to install and install a crossflow. Alternately, there have been people who cut out the raised portions of the existing 65/66 support to create a larger opening. This would certainly require a lot less work than what I did. This would require that you be a little more creative with the top mount.
Because I try to make my car a sleeper, I used a 4 row copper brass 67-68 AC radiator. I used a 67/68 top radiator mount and fabricated the lower mounts. Here is a couple of pics of my 65' with the 67-68 core and radiator installed:
mustang-aluminium-radiator-upgrade-1img_0788_tn.jpg   mustang-aluminium-radiator-upgrade-1img_0983_tn.jpg
Dennis
11.52@121.29mph
11-14-2007, 08:46 PM   #8 (permalink)
frdnut
Originally Posted by n2omike View Post
Hey frdnut,
Good Luck!
No Mike the outlet is straight back...I could not believe how easily this thing swapped in.
11-17-2007, 12:27 PM   #9 (permalink)
ZephyrZ7
Question Re: Mustang aluminium radiator upgrade
Now I'd bet an extremely hot summer day in Ontario Canada isn't quite the same thing as an extremely hot summer day in Texas! The birds here use oven mits to pull worms out of the ground on those days!
Seriously though, how hot does it get and what kind of humidity do you see? I've been torn as to whether or not I should go with an aluminum rad. or not but I keep hearing conflicting stories as to what is better.
There is a fine line between a hobby.... and mental illness.
11-17-2007, 01:34 PM   #10 (permalink)
FATNFAST
I thought this was interesting.
U.S. Radiator Testing
Rick in Indy "408 Clevor" 10.525@133.17
FATNFAST is online now   Reply With Quote
HTML code is On
Aluminium Radiator fastfalcon1967 Falcon Pages 17 09-20-2007 09:41 PM
Anyone running an aluminium rad in a 67-70 mustang? frdnut All Ford Techboard 9 06-03-2007 09:55 PM
radiator upgrade question NoLongerHere2 All Ford Techboard 14 06-13-2005 11:34 AM
Classic Cooling Upgrade NEEDED...Radiator Style?? 67fastback All Ford Techboard 17 12-14-2004 07:56 PM
I need a new radiator. Will a mustang radiator fit in a 64 289 Galaxie? norcal500 Galaxie Pages 4 09-22-2004 11:38 PM
