02-03-2008, 02:30 AM   #1 (permalink)
shumakerscott
Tech Magnets to Aid Filtration
I've been reading here and on other forums about buying Neodium magnets to put on your oil filter and oil pan. You don't have to buy them! There are thousands of them for free. All you need is a junk hard drive.
You will need a Torx 8 screwdriver, maybe a Torx 7 also for some drives. Remve the top. (Note)There are hidden screws under the stickers.
The magnets are in the corner at the end of the pickup arm. There may be screws holding the magnet assembly. Very old drives like this 5 Gig only have one magnet but most have 2. Get the assembly out any way you like.
Put them in a vise and bend the backing plate to loosen the glue.
Slip a screwdriver under it and you have a free magnet. (Warning!! Some of these magnets are VERY strong and will jump. Watch out for pinched fingers) Another source for smaller ones come from CD/DVD drives. The optical laser uses small magnets for focusing. These work great on drain plugs. Every motor I have has a magnetic drain plug. You must JB Weld them if you have a steel drain pan. Aluminum blocks like motorcycles don't require it but is safer. You can put them on the outside of your oil filter or on the bottom of your oil pan. If you use them on the oil pan you should remove them before draining the oil. This will let the bad stuff drain out. I hope this will be of use. Let me know if you find other uses for these magnets.
[SIGPIC][/SIGPIC]
I look pretty young but I'm just back-dated
64 1/2 Coupe "Homer"
shumakerscott is offline   Reply With Quote
02-03-2008, 10:14 AM   #2 (permalink)
Re: Magnets
Schu! That's awesome!
02-03-2008, 10:55 AM   #3 (permalink)
72BlackOnBlack
Re: Magnets
HA! Now I'm really really happy that I've kept a few blown hard drives lying around.... Great idea!
72BlackOnBlack is offline   Reply With Quote
02-03-2008, 01:23 PM   #4 (permalink)
CWallace
Re: Magnets
I like free cool stuff. I too have some bad hard drives setting around. Never knew why untill now.
CWallace is offline   Reply With Quote
02-03-2008, 04:06 PM   #5 (permalink)
MusclePoney
Thumbs up Re: Magnets
X2!!!
Thanks!
MusclePoney is offline   Reply With Quote
02-05-2008, 01:13 AM   #6 (permalink)
mrboomy
Re: Magnets
You should try taking the magnets out of old 5.25 inch SCSI drives. They make the ones out of newer drives look TINY! I played with them enough to know that it hurts like HELL if you slip with them. I had a NICE BIG blood blister to prove it too.
2002 Volkswagen Jetta GLI 24V VR6 6 speed
1998 Ford Taurus LX 3.0 Vulcan OHV
mrboomy is offline   Reply With Quote
02-07-2008, 01:13 PM   #7 (permalink)
Murff
Re: Tech Magnets to Aid Filtration
So far I have used HDD magnets to aid in fitting my replacement fireall and to help keep fender covers from sliding away.
If you use these things to put the pictures your kids drew on to the refrigerator you will proabaly pull the 'fridge over on its side before you get the magnet off.
These critters stick!
Murff
Peace, Love, and Groovy Vibes
Murff is offline   Reply With Quote
02-13-2008, 02:47 PM   #8 (permalink)
shumakerscott
You can make wind chimes out of the discs if your into that sort of thing.
[SIGPIC][/SIGPIC]
HTML code is On
Has anyone here used \"Filtermag\" oil filter magnets ? gchero351 All Ford Techboard 3 08-21-2005 02:50 AM
tech 64 TBOLT The Garage 2 02-14-2005 05:41 AM
Those little magnets... coupe3w The Garage 1 07-16-2004 07:48 AM
need more tech mattsw66 The Garage 16 05-19-2004 06:34 AM
G=Tech Pro coupe3w The Garage 1 01-12-2003 09:06 PM
