04-19-2008, 01:54 PM   #11 (permalink)
fastcoupe68
Re: 408 Stroker Camshaft Dyno Test
Originally Posted by boullestergm View Post
One reason why the first readings may seem high is because Westech's dyno is known as "Puff the Magic Dyno"!
Just in the same way that TEA's Flowdata flowbench is known as "Puff the Magic Flowbench"!
Still great tool for before/after tests... not so great for legit first test numbers.
Whats the deal with TEA? Was about to send a set of TFS R heads to them?
fastcoupe68 is offline   Reply With Quote
04-19-2008, 09:29 PM   #12 (permalink)
admin
Book promo = bogus dyno test? Come on now! We aren't hiding the fact that we are promoting a book (we thought the picture of the book and link to Amazon was rather obvious )
Engine dyno pulls generally begin much higher than chassis dyno pulls. The numbers below 3K are not that significant when this engines power curve is 3K and up.
I'll work on getting Holdener to post some more info about this test - but I vouch it is not fabricated. 500+ at the crank on a 347 is actually "good", not "mind blowing impressive".
Always glad to see whose reading this stuff, keep it coming!
Chirag
admin is offline   Reply With Quote
04-19-2008, 10:18 PM   #13 (permalink)
fastcoupe68
Chirag
I thought they were testing a 408?????
04-20-2008, 09:08 AM   #14 (permalink)
admin
Yes, they were...LOL, sorry I had 347 on the brain from another project. In retrospect, 500 from a 408 is sort of middle ground achievement.
04-20-2008, 01:21 PM   #15 (permalink)
fastcoupe68
I have a 408 w/10-1 comp and windsor sr. heads, solid roller with just around 550 lift that made 480 hp at 6000 rpms The 408 in question has way more cylinder head then mine so this does not sound to far fetched to me at all.
04-20-2008, 03:03 PM   #16 (permalink)
dbu8554
my only question not to be a **** or anything is what does this have to do with the tech exchange?
HTML code is On
521 BBF DYNO TEST 830 HP 701 TRQ DynoTom FM Video 5 03-06-2007 12:26 PM
Costs for a dyno test. slyman2087 Late Model EFI Techboard 5 02-08-2005 08:25 PM
HO Camshaft with a 331 Stroker tiger260 Stroker Engines 1 01-20-2005 05:11 PM
347 stroker camshaft ideas? austfairmont66 All Ford Techboard 1 06-11-2002 05:06 AM
frp 392 dyno test XE460 All Ford Techboard 2 03-20-2002 06:40 AM
