05-08-2008, 04:15 AM   #11 (permalink)
KULTULZ
Unhappy Re: A Proper PCV
Originally Posted by FEandGoingBroke View Post
Hold on a second Kul...
The system Mr. Mikelonis has is almost as closed as they get...
Read it this way if you will.
Valve cover with PCV valve conected to vacuum port.
Hose going from opposite valve cover to the air filter housing.
Sure it's a closed system, but... The inlet hose to the VC goes to the filter housing but it draw's air from OUTSIDE the Filter, through a small piece of Poly-Cotton Batting...
That poly-cotton batting is nowhere near as efficient at filtering the air as that cute little Washable K&N filter that Jon uses...
So I think the Closed PCV System is a little out done here...
What do you think of my pint of view?
FE
I made a mistake. But the system shown is an OPEN PCV SYSTEM, i.e. the source of fresh air is exposed to the atmosphere allowing fumes to also enter the atmosphere. A CLOSED SYSTEM draws fresh air from within the air cleaner housing and any fumes are contained in the air cleaner asm and hopefully burned.
I confused (not too hard for me) the mesh installed under the valve as the fresh air inlet filter. Obviously that is on the opposite rocker cover. The mesh filter will over time fill with an oil mist causing a vacuum drop, so it must be serviced on a regular basis as does the inlet filter and valve.
[FONT=Century Gothic][/FONT]
05-08-2008, 07:48 AM   #12 (permalink)
Re: A Proper PCV
Ohhh, ok I see what you're saying now. Thank you.
05-08-2008, 08:22 AM   #13 (permalink)
KULTULZ
Post Re: A Proper PCV
Yeah, I got my lips over my eye teeth first time and couldn't see what I was saying...
There is nothing wrong with the way he is going about it but it will require more attention.
05-18-2008, 07:10 PM   #14 (permalink)
galaxie500joe
Re: A Proper PCV
where do you get the extensions for the pcv valve and breather?
galaxie500joe is offline   Reply With Quote
05-18-2008, 11:41 PM   #15 (permalink)
KULTULZ
Question Re: A Proper PCV
What do you mean exactly?
05-19-2008, 09:49 AM   #16 (permalink)
galaxie500joe
Re: A Proper PCV
The black plastic risers on the valve covers for the breather and pcv valve.I have never seen them. Do they come with that particular valve cover?
I would like to get them for my engine..
05-19-2008, 10:15 AM   #17 (permalink)
Mikelonis
Re: A Proper PCV
see caption #2 in this article. They're from Comp Cams.
http://www.fordmuscle.com/archives/2...vers/index.php
05-19-2008, 05:00 PM   #18 (permalink)
galaxie500joe
Re: A Proper PCV
Hey Mike
where did you get them? I have been searching with no luck
Thanks Joe
05-20-2008, 10:07 AM   #19 (permalink)
Mikelonis
Re: A Proper PCV
Joe,
Well, it looks like Comp Cams discontinued their polymer valve covers. Those "breather stands" appeared to be part of that line. Sorry. You may need to call the Comp sales line for help.
Jon
05-23-2008, 04:11 PM   #20 (permalink)
galaxie500joe
Re: A Proper PCV
Thanks Jon
yes they are discontinued but I was able to get them direct from comp cams
HTML code is On
Proper Ring gap jagfandaddy All Ford Techboard 6 04-19-2008 09:18 AM
Proper pushrod length? Strangeleek All Ford Techboard 2 07-29-2007 06:07 PM
Proper PCV routing? Jeffhynes Mustang Pages (1979-1995) 6 05-04-2007 08:33 PM
proper backspacing boozeprince Fairlane Pages 1 03-03-2007 03:33 AM
Why to always use the proper tools... 89Trooper The Garage 19 02-16-2005 06:33 PM
