C6 trans were also put in 1966 thunderbirds with 390's. The 66 models used the cruise-a-matic shift pattern, so looking at the gear selector wont help. C6 trans used an all aluminum case. Cruise-a-matic had a cast iron main body. Ford fairlane GTA had what was called the sport shift valve body. This pattern was used from 67 on up. That is why you can't get a shift kit for a 1966 C6 !
The cruise-a-matic was used in the 62 thunderbird. This tranny can't handle any dirt. Keep it serviced frequently or it will develop shifting problems.
originally came with 390 4v C6 automatic and 3.0 open rear
Now Has
390 V6 (tri power from a 62 thunderbird) + mods
T45 5 speed from 2000 cobra
4:11 richmond gears Posi
digital gauges and speedo ( to calibrate speedo easily)
<font size=-1>[ This Message was edited by: casscomputers on 5/18/06 11:35am ]</font>
