66 Tbird trans
Actually, 66 Birds also came with Cruise O Matic trannys.
I have two of em, neither has a C6.
On the driver's door, there is a plate with codes. This will give you engine, tranny, gear ratio, plant, color, and other stuff.
I have some great resources and original shop manual for TBird help.
If you send me the codes from the door, I will look up the specs for you. Drop me a line and I'll point you to some forums, etc. these cars have a lot of things that are pretty "odd" due to the fact that they were cutting edge at the time. Things like the lifting of the shifter to start the car, are things all "flair bird" owners can help you with.
Cheers
Scott
