07-24-2006, 10:32 PM   #1 (permalink)
XDPSxxSTANGxxRACER
No Start! Help!!
On my 64, I tried starting it after about a year of sitting in my garage. I thought the coil went bad so I took the coil off my 75 Dodge van. I poured gas in the carb and went for a start. After trying and trying I stuck a screwdriver in the coil wire and arced it against some bare metal and found out I out was getting no spark. What else would cause a no spark condition? I checked the ground wire and it seemed tight. I was think maybe ignition module? Any suggestions?
Greg
XDPSxxSTANGxxRACER is offline   Reply With Quote
07-25-2006, 12:00 AM   #2 (permalink)
No Start! Help!!
POINTS stuck open or closed? Power to the Coil? Bad Ign Module maybe if you're useing the more modern stuff....
FE
07-25-2006, 06:14 PM   #3 (permalink)
XDPSxxSTANGxxRACER
No Start! Help!!
I forgot this was a points car. Your the 2nd one that has mentioned points. I was also told they can go bad when a car just sits. I assume I was getting power to the coil as it was getting warm while I was cranking on the car.
07-30-2006, 11:05 PM   #4 (permalink)
No Start! Help!!
You were getting power to it allright....
Clean the points up and try it again.
FE
