08-03-2007, 08:27 PM   #1 (permalink)
carnutt51
Turbo Coupe Trans Swap
Does anyone know whether a C4 Transmission will bolt up to a stock 1985 Turbo Coupe bellhousing without a special adapter kit? Plus, how much trouble am I looking at if I decide to perform the swap?
Tom McDowell
carnutt51 is offline   Reply With Quote
08-03-2007, 08:35 PM   #2 (permalink)
mustang42782
Re: Turbo Coupe Trans Swap
there are C4's for the 2.3 4 cyl. You have to find the right one is all then get the right drive shaft and rad with cooler Good luck !
08-05-2007, 06:01 AM   #3 (permalink)
carnutt51
Thanks for the info and help. If bad goes to worse, I'll find a 302 w/auto and replace the whole shooting match. Thanks again!
Tom McDowell
1985 turbo coupe, need one? eliteman76 Thunderbird Pages 12 04-18-2007 05:18 PM
T bird Turbo Coupe-late 80\'s v8shadow All Ford Techboard 18 04-12-2006 07:53 AM
\'87 Tbird Turbo coupe won\'t run, need help!! BobbyD All Ford Techboard 3 12-20-2003 04:39 PM
88 turbo coupe smoking bad iflipcars All Ford Techboard 9 09-17-2003 12:51 PM
Turbo coupe - years and steering ratios? dirtball All Ford Techboard 5 06-05-2003 10:56 PM
