12-29-2007, 08:48 AM   #1 (permalink)
booboo412
to all 67 68 and 69 tbird owners
hi guys, i live in england so i have trouble getting help
on your oil pressure guage on ur dash - where does your needle sit when the car is idling. mine sits just after the letter L where it says OIL in the middle
is this correct????????
booboo412 is offline   Reply With Quote
12-29-2007, 09:39 AM   #2 (permalink)
trikar
Re: to all 67 68 and 69 tbird owners
When you say "just after" you mean the Driver's side, and if so, you are saying that the needle stays between the driver's side door and the "L" on your gauge. That is not normal, just to the passenger side would be normal, but what is important is where does the needle go once the car is warmed up and running. If the needle still stays down there, try to change the oil pressure switch, it is located at the back of the Block. If you are still getting a low reading ,do an oil pressure check. How is the car driving? Do you have a 429,428, or a 390?
trikar is offline   Reply With Quote
12-30-2007, 04:12 AM   #3 (permalink)
booboo412
mines a 69 429. just had new presseure switch fitted a few weeks ago.
i would say that when the car starts the needle points about 1 o-clock, it goes up about 3/4 of the way towards 'high pressure' . not between the drivers door and 'L' more like etween the passenger door and 'L' if you understand me. when the car heats up and im driving around it just stays covering up the letter 'L' too
12-30-2007, 10:52 AM   #4 (permalink)
trikar
Try removing the oil pressure switch and checking the oil pressure with a gauge mounted in the opening for the switch. Sometimes the new switches are bad, also chech the wiring from the switch to the gauge.
03-04-2008, 12:46 PM   #5 (permalink)
69thunderbird
when i changed the oil with a thicker/higher viscosity, my 69 thunderbird started going up to H when cold and back down to 3/4 when warm. think readings can be dependent on what type of oil you use, and if your vehicle is quart low or not. quart low and 'thin' oil can reduce the pressure and give you a lower than normal (whatever normal is) reading. wouldn't start replacing anything since you may end up replacing a working pressure gauge with a defective/wrong style.
69thunderbird is offline   Reply With Quote
347 into 88 TBird slvr98svt Late Model EFI Techboard 3 07-07-2006 10:53 AM
88 TBird 5.0 to 351 slvr98svt Late Model EFI Techboard 2 04-13-2005 03:02 PM
My 93 Tbird is ALMOST done 392Bird Late Model EFI Techboard 7 09-20-2004 09:45 PM
tbird was EFI tbirder Late Model EFI Techboard 28 10-03-2002 03:38 PM
Tbird Shadowkeeper All Ford Techboard 6 05-09-2002 09:26 PM
