01-19-2008, 03:08 PM   #1 (permalink)
booboo412
battery power
i need to get a bigger battery for my 69 with the 429 bb in it. i figured the crank amp is too low (520) as the battery dies all the time and it is slow at cranking over - allways sounds as if the battery is dying when i start it and its a new battery , im going to be installing a big stereo in it with a few tv screens etc and i want enough juice so what do i need
whats advised, should i also have another one wired up in the trunk as a backup one or something
booboo412 is offline   Reply With Quote
01-19-2008, 03:47 PM   #2 (permalink)
Re: battery power
Youanswered your own post... You need about an $80 dollar 800 CCA battery
Might want to upgrade your alternator too. Many car's were produced with two choices for alternators... 55-60 amp and 75-100 amp something like that.
FE
01-20-2008, 04:01 PM   #3 (permalink)
booboo412
Re: battery power
cheers :-)
01-20-2008, 04:18 PM   #4 (permalink)
Re: battery power
G2BOFHelp M8!
93 stang with full power load, the voltage from battery drops pretty good!!! XolieX All Ford Techboard 3 10-03-2004 12:04 PM
power steering pump fittings for a mustang II power rack gtnrb71 All Ford Techboard 1 06-10-2004 11:10 AM
Wiring ... Primary power leads form the Alternator/Battery MonsterMach All Ford Techboard 6 03-01-2004 09:31 PM
Master Power Power Brake Conversion 69convert All Ford Techboard 10 09-19-2003 03:37 PM
At which power level does 2,5\" dual exhaust start to restrict power output? ville All Ford Techboard 15 04-23-2003 11:35 AM
