02-11-2008, 04:51 AM   #1 (permalink)
lees6t
Disc brakes on a '57 Bird
I'm in the process of installing disc brakes on a friend's '57 Bird. He bought a kit from someplace (don't know who or where at the moment) and so far,it's going together well.
My only concern, other than the fact that he's 85 years young and I hope I get it finished
before before he expires, is the close proximity of the master cylinder to the exhaust manifold (about 3/8"). The original m/c uses a sheetmetal shield between it and the manifold, of which I'm thinking of tacking an additional 3" of metal, but that leaves very little space for heat dissipation. Has anyone done a similar conversion and had this problem? I don't want him to be driving the car if the radiant heat is going to be boiling the fluid or melting piston seals. Thanks for any replies
Lee
'60Falcon 302/AOD
"54 Ford sedan 351W/c4
lees6t is offline   Reply With Quote
06-05-2008, 08:20 PM   #2 (permalink)
slcbca
Re: Disc brakes on a '57 Bird
Lee
Hi Lee, Guess by the date you've finished the project, but...I do understand the concern. I installed a disc front and dual zone system using a '78 mustang master Cyl. on my 1955 T'bird. I spliced a piece into the heat shield so that it would extend to the end of the new M.C. I converted to sylacone brake fluid because I think it has a higher heat tolerance. I sure did worry about cooking the brake fluid! I've had no problem in 3 years but still worry. The car is a street rod and I just installed Sanderson headers, which gives me a lot of clearance.
Regards, Steve
slcbca is offline   Reply With Quote
Master cylinder with Disc/Disc brakes GT200Z Mustang Pages (1965-1973) 23 06-29-2006 08:38 PM
Master cylinder with Disc/Disc brakes GT200Z Mustang Pages (1965-1973) 2 04-25-2006 07:43 PM
brakes on a 82 t-bird machtang All Ford Techboard 2 11-23-2004 01:34 AM
disc brakes on a 56 t-bird eyechsr All Ford Techboard 2 10-19-2004 01:17 PM
Frt Disc for my 55 Bird DelC All Ford Techboard 2 08-29-2003 03:14 AM
