03-03-2008, 05:32 PM   #1 (permalink)
going slow
88 bird.. 8.8 rearend question..
can i swap the axles and disc set up from a crown vic to my 88 bird? i know ill have to shorten the axles but this wa i can have disc and 5 lug
going slow is offline   Reply With Quote
03-08-2008, 02:34 PM   #2 (permalink)
Pegleg302
Re: 88 bird.. 8.8 rearend question..
I think finding a Mustang 8.8 with disc brakes would be a lot less work. I have an '88 Tbird, and am thinking about a swap also. Check into Lincoln MKVII rears, someone told me it is an easier swap. Axles for a conversion, plus narrowing a rear can be very expensive.
Pegleg302 is offline   Reply With Quote
04-04-2008, 08:57 PM   #3 (permalink)
vinnietbird
The BEST and easiest way is to find an '87 or '88 Turbo Coupe Thunderbird.They all have 8.8 disc rears with traction Lock.The manual tranny cars have 3.55 gears,and the automatic cars have 3.73 gears.If you were near me,I have an extra 8.8 with 3.55's in the garage.The mark VII rear probably has 3.08 gears,and,it'll be one inch wider on both sides.If you go with the disc rear from a Lincoln mark VII or T-Bird,you'll also need to grab the parking brake cables and you'll need to upgrade your master cylinder.One for a '93 Cobra is great.Good luck.
vinnietbird is offline   Reply With Quote
04-27-2008, 06:21 PM   #4 (permalink)
Pegleg302
Hi Vinnie, small world!!
a question about rearend 63Sean Galaxie Pages 6 12-03-2006 01:50 PM
9 inch rearend question tirefryer All Ford Techboard 2 04-03-2005 09:17 PM
Ive got a rearend question fairlanes4ever9 All Ford Techboard 4 09-07-2004 02:11 PM
9\" Rearend Question GregS All Ford Techboard 2 12-22-2003 09:26 PM
Another rearend question 63Ford All Ford Techboard 5 04-16-2003 12:42 AM
Holley
