06-20-2008, 02:51 PM   #1 (permalink)
A52894
front clip
I have a 1995 T-Bird with a rather bland looking front end. It would appear that a nose clip from a 1995 Mark V111 would bolt right on to it. Does anyone know if this is easily done?
A52894 is offline   Reply With Quote
06-20-2008, 03:32 PM   #2 (permalink)
WUWU20
Re: front clip
I'm not gonna say it can't be done but it would take someone that really, REALLY knows what they're doing, it wouldn't be as simple as just changing out parts. The leading edge of the T-bird door has a very differnet line to it then the Mark, the Mark has a "hump" in the body line about mid way down the body and the T-bird has none so that would be a issue and then theres the hood. I'm sure there is very little difference in the front unibody between the two but the rest of it would be some work. I have a 1996, I have always felt that the 96-97 had the best looking front nose.
1970 LTD 2dr ht...351W
1996 Thunderbird 4.6
sniff, sniff.....who did that?
www.myspace.com/wuwu20
WUWU20 is offline   Reply With Quote
06-25-2008, 05:48 PM   #3 (permalink)
A52894
Smile Re: front clip
Thanks for the information in regard to the clip replacement. I think I will forget the idea.
06-30-2008, 05:55 PM   #4 (permalink)
392Bird
Re: front clip
What you could do, is swap 96-97 head lights to it. To do that, you would need to also use the headers panel (the black plastic piece that the head lights bolt to) and a 96-97 hood. I think the 94-95 bumper cover and 96-97 headlights makes a great looking combination. The 96-97 head lights look MUCH nicer, but requires the 96-97 hood to fit correct.
393 stroker, Vortech YSi on E85
3,500 rpm converter, 3.55 gears, Detroit Locker
17x9 Cobra Rs, with 255/45/17 front, 275/40/17 BFG DR rear
http://members.tccoa.com/392bird/
392Bird is offline   Reply With Quote
07-12-2008, 06:28 AM   #5 (permalink)
A52894
Re: front clip
Thanks for your idea of replacing the headlights and hood.It could be done at a reasonable cost.I have learned that my previous idea was impossible.
72 Front clip grezmico Torino Pages 6 12-31-2007 03:16 PM
62 front clip available v8shadow Galaxie Pages 5 12-21-2007 11:30 AM
fiberglass front clip???????????? 70 mach daddy Truck Forum 1 10-24-2007 10:17 PM
Front clip replacement??? Yesdogjr Mustang Pages (1965-1973) 6 04-29-2006 01:04 PM
Front clip removal 67galaxie500 Galaxie Pages 2 01-28-2006 06:50 AM
