08-11-2008, 05:16 AM   #1 (permalink)
avelen
66 tbird
I was given a 66 tbird a few weeks ago from a family member, im working on restoring it but ive hit kind of a brick wall.
i cant for the life of me get the Distributor out, any advice on how to get it out of there?
avelen is offline   Reply With Quote
08-12-2008, 09:18 AM   #2 (permalink)
gts340
Re: 66 tbird
Well, I'll assume you have removed the distributor bolt and hold down. Does it just not pop out for you? If that's the case, try to twist it back and forth a bit and wiggle it to get it to work itself loose. Sometimes they sort of "POP" out.
gts340 is offline   Reply With Quote
08-12-2008, 10:23 AM   #3 (permalink)
Re: 66 tbird
remove the bolt and lift and twist... Just lift hard
Spray the bottom with carb cleaner to loosen teh hardened oil.
08-27-2008, 08:34 PM   #4 (permalink)
redneckprofessor
Re: 66 tbird
Sometimes they are pretty friggin' hard to get out. I bought a junked 460 block, and the aluminum shaft of the distributor broke in the block, so just the collar stuck out. I actually had to grind away at the thing to get it thin enough to fold in a little when I hammered on a punch on the collar. Once it moved, I had to use a crowbar to finally get it out. That was just the collar, mind you.
No one believed me that the dang thing wouldn't just "come out" when I pulled on it.
So, if everything is loose, you may have to hammer on it to get it loose (assuming that you are buying a new distributor, though). Or, pry in it carefully with a pry bar. But I agree with FE (as usual), spray some carb cleaner, or even liquid wrench, and keep at it.
FORDS-- betcha can't have just one!
redneckprofessor is offline   Reply With Quote
08-27-2008, 09:01 PM   #5 (permalink)
Re: 66 tbird
That little schitt never came back
347 into 88 TBird slvr98svt Late Model EFI Techboard 3 07-07-2006 11:53 AM
96 TBird oldude All Ford Techboard 6 06-02-2005 10:40 PM
My 93 Tbird is ALMOST done 392Bird Late Model EFI Techboard 7 09-20-2004 10:45 PM
tbird was EFI tbirder Late Model EFI Techboard 28 10-03-2002 04:38 PM
Tbird Shadowkeeper All Ford Techboard 6 05-09-2002 10:26 PM
