06-02-2009, 06:13 PM   #1 (permalink)
jerrym3
94 AOD trans
My 94 TBird trans is starting to drop out of gear. It was rebuilt about two years ago (2nd rebuild), but I have put very few miles on the car since then.
Is their a trans additive product from Lucas, or another mfg, that might help?
Where can I go to buy the product?
I really don't want to sink any money into her (144,000 miles), so if the slipping gets bad, it's wrecking yard time.
jerrym3 is offline   Reply With Quote
06-02-2009, 06:33 PM   #2 (permalink)
gbic1
Re: 94 AOD trans
Need more info. What gear is it dropping? How is you tv adjustment.Miracle cure only work on transmissions with hard seals. Seals wont get hard in 2 years.
1964 Galaxie 428
1966 Mustang 302
1967 Cougar 390
1968 F250 Camper Special 390
06-03-2009, 05:42 PM   #3 (permalink)
jerrym3
Re: 94 AOD trans
Seems to be dropping out of 4th at both low and highway speeds.
Nothing like the original 3-4th shudder that a lot of these transmissions had.
06-03-2009, 05:43 PM   #4 (permalink)
tbirdtess
Re: 94 AOD trans
Hello
A 94 T-bird would have a 4r70w trany.
Paul
PAUL
1990 #12 T-Bird Stock Car
1996 T-bird (to replace the 90)
1985 T-Bird Coupe (work in progress)
tbirdtess is offline   Reply With Quote
06-04-2009, 05:53 PM   #5 (permalink)
jerrym3
Re: 94 AOD trans
I should have noted that the drop seems to be 4th to 2nd, not 4th to 3rd.
06-24-2009, 03:58 PM   #6 (permalink)
SnakedMark8
Re: 94 AOD trans
Try setting the MLPS or replacing it. That's a common problem with those trans.
SnakedMark8 is offline   Reply With Quote
07-04-2009, 08:15 PM   #7 (permalink)
55 f350
Re: 94 AOD trans
whens the last time you changed the filter and fluid ??? just bought a 95 with a 4.6 and the 4r70w really cheap as the guy who owned it complained of this and a nasty vibration in it . i talked to a cuz who worked in a trans shop as their ford guy for 20 plus , and after hearing what i told him he said change the above mentioned and drive it it should clear up if it hasnt been let go too long . seems that there is a sensor in the thing somewhere that controls the lockup on the converter that gets polluted from dirty fluid and will cause it to do weird stuff . i did it and mine cleared up within a few hours . no more " hunting for a gear " or feeling like it was dropping out as you put it and the vibration which was it locking and unlocking partially . got the car for $200 though as this kid didn't know .............
55 f350 is offline   Reply With Quote
07-20-2009, 05:49 PM   #8 (permalink)
jerrym3
Re: 94 AOD trans
I haven't done anything regarding the trans yet.
I figured that she was probably not going to pass NJ state inspection, and, if she failed and it was something major, I was going to dump her or give her to my daughter's boyfriend (he's a BMW mechanic).
So, I was shocked when she passed inspection this morning!!
145,000 miles, still on the original factory exhaust, and uses less than a quart of oil every 1,500 miles (4.6 sohc).
Except for the transmissions, these were great cars.
Unfortunately, I just noticed that the northeast winters have finally done damage. Rocker panel has rust.
c-4 trans Trey C4 Transmissions 3 05-15-2008 10:09 AM
C-4 Trans dumping trans fluid Roarnracin All Ford Techboard 5 05-16-2007 06:58 AM
Trans brake , won\'t hold above 3500 rpm\'s , new trans ! HELP ! bad4rd C4 Transmissions 9 08-17-2006 06:21 PM
AOD trans airframe2001 All Ford Techboard 6 03-19-2005 06:43 PM
tci trans?? crhumper C4 Transmissions 1 09-04-2003 06:20 PM
