06-04-2009, 09:23 PM   #1 (permalink)
robban500
my 66 428 will not burn tires
hallo guys can some one tell me why it not will burn tires when i step it down i cant even brake lock the car it will not burntires timing is set new carb and new timing chain and sprockets everythning is correct set
robban500 is offline   Reply With Quote
06-05-2009, 05:36 AM   #2 (permalink)
65fbstang
Re: my 66 428 will not burn tires
How does the car accelerate? Even pull or does it reach an rpm and then seem as though it comes alive, and also what rpm do you reach when under brake lock and full throttle? Is this a new combination for the car?
65fbstang is offline   Reply With Quote
06-05-2009, 06:34 AM   #3 (permalink)
robban500
it accelerates almost normal from 0-60 i can brake lock it up too 2800 then it sounds ( buao) something like that no it isnt something new
06-05-2009, 07:20 AM   #4 (permalink)
65fbstang
I know I am asking questions and not answering your's, but I am just trying to get a better handle on the problem. I assume you are sure the cam is in straight up and not off? What carb and distributor are you running? I asked about the rpm wondering about the converter, but if the set up is not new then you did not have this problem before. I had a car that would not spin the tires at all, but upon accerleration it would come alive about 2800 rpm (problem was wrong converter).
06-05-2009, 09:00 AM   #5 (permalink)
kuumakyyticom
Exactly same here, lazy 66 built 428 on my gal !
It accelerates ok from 30 mhp to 70 mph,
0-60mph very slowly , max rpm ca 2500-2800 rpm,
when secondary vacuum venruris open , sboooooooo sound and nothin happends.
At normal traffic, typical zero to 40 mph, goes easy, rpm 0-1600 rpm.
Very drivable, but no way burn rubber.
1964 Ford Galaxie 500 XL ragtop
http://www.cardomain.com/ride/2192552
http://www.kuumakyyti.com/ragtop64
Any extra rockauto magnets, ANYONE ???
kuumakyyticom is offline   Reply With Quote
06-05-2009, 09:58 AM   #6 (permalink)
robban500
everything has correct set up carb is a new edelbrock 750 (1407) distrubutor original but with petronix kit correct set that too 3,00 rear end converter original . must be converter as you said
06-05-2009, 10:03 AM   #7 (permalink)
robban500
hi are you going too power meet in sweden your car sounds like mine tbird i hope my galaxie will be much better when its ready
06-05-2009, 12:09 PM   #8 (permalink)
kuumakyyticom
I have both 600 cfm and 750 cfm edelbrocks, both works same way, perhaps with 600 cfm little better, pertronix inside, 3.00 rear end.
COnverter installed in states, late 80`S early 90`s
Does torq converter really steal power so much, that car lost it`s power ?
From where to find correct one..
66/67 428, flexpalte and starter are 66/67 models..
Trans.. no idea.. middle case.. perhaps orginal..
Really odd Trans identification place
PCE AU = column shift 390 -4V
1 = Detail change
engine displacement= 097 WTF !!!!!!!! So small engine !!! LOL
date code = 131 what ever that means !
06-05-2009, 12:13 PM   #9 (permalink)
65fbstang
A converter is a torque multiplier and will let the car get to the rpm level that is in the torque curve to provide greater launches. Picking a converter should be left to a converter shop and they will need lots of information to better pick a stall speed that suits your situation such as rear end gear, weight of vehicle, motor horsepower and torque, and size of tires. As I posted earlier I have been through this before and if the wrong converter is in place it seems as though the car has no power off the line and has to fight, so to speak, until it gains enough rpms. I have purchased from West Coast Converters and have been pleased wi the service and product. wcc@westcoastconverter.com
06-05-2009, 01:32 PM   #10 (permalink)
robban500
ok thanks for answers now i know my car is normal i juse the bird as a daily driver summertimes (just waiting to get my engine back to my gal so i can burn some rubber) my freinds tasees me cause my bird cant burn rubber they have bonnevilles 65 421 3 power and impala 409 -65 and chevelle70 454 ss cars
galaxie500 stroker446 -64 . galaxie500xl conv-64. t-bird sportscoupe 428-66
Will 16 tires make a difference over 15 inch tires 82GT All Ford Techboard 14 01-21-2006 08:52 PM
tires to burn 64 TBOLT The Garage 16 03-01-2005 12:51 PM
on late motel SUV\'s, can you really burn up your transmission if you put larger tires? XolieX All Ford Techboard 7 09-25-2004 12:42 AM
Burn baby burn thread reminded me of something.... CaptVirgilHilts The Garage 5 09-07-2004 01:57 AM
Burn baby burn! Falcon0311 The Garage 2 09-04-2004 12:03 AM
