09-19-2009, 06:05 PM   #1 (permalink)
rod123
66 t-bird radio
I have a 66 T-Bird radio I would like to test to see if it works ok so it has 4 wires coming from the side of the radio.
I expect the 2 black wires with a plug on the end to be speaker wires but I have a yellow wire and a blue wire also going to a plug.
If anyone knows I need to know which wire would be the hot wire that I can safely hook up 12 volts going to that wire to power the radio.
Thanks Rodney
rod123 is offline   Reply With Quote
09-19-2009, 06:32 PM   #2 (permalink)
jeffstar
Re: 66 t-bird radio
I'm 99% sure the blue and yellow wires are The +12V for the radio, and display light (dimmer circuit).
Ground is through the chassis.
65 Fastback:393W, G-Force 5spd, 4.11:1 Moser N-pro case / 31 spline axles, 4 wheel Disc (low 11's)
09-19-2009, 06:37 PM   #3 (permalink)
rod123
Re: 66 t-bird radio
Thanks for your quick response, I will try it tomorrow.
Radio Ralphw Torino Pages 0 12-02-2007 12:42 PM
AM/FM radio in 63' fredetl Galaxie Pages 2 08-21-2007 06:31 PM
radio radio brentville Galaxie Pages 0 07-06-2006 09:09 PM
radio add on\'s brentville Galaxie Pages 7 06-27-2006 10:16 PM
CB radio bandit The Garage 24 10-21-2003 02:12 AM
