05-20-2002, 02:14 AM   #1 (permalink)
Torino500351C
What size rearend?
I have a 71 Torino 500 with a 351C 2V. I don't know what size the rearend is, or how to tell. Is it a 8" 8.8" or 9"?
Torino500351C is offline   Reply With Quote
05-20-2002, 07:17 PM   #2 (permalink)
Shep927
What size rearend?
Should be a tag somewhere on the rear that contains a bunch of numbers. On mine it was on the front section close by the pinion. If you can find it, post the info and someone here should be able to decode it.
Shep927 is offline   Reply With Quote
06-30-2002, 01:04 AM   #3 (permalink)
MGT351
What size rearend?
If it is a 351 car it should have the 9", as far as I know only the 302 and 6cy cars got the 8"
MGT351 is offline   Reply With Quote
06-30-2002, 07:14 AM   #4 (permalink)
brianfulwood
What size rearend?
It should be a 9" as stated above. One way to tell a 9" from an 8" is by looking at the two lower diff case nuts/studs. If you can get a socket on them, the rear is an 8". the 9" has a hump in the case, protruding downward; you won't be able to get a socket on the 9".
Probe Industries
