03-05-2004, 12:10 PM   #1 (permalink)
Rancho Lenny
Fuel Pressure Dissapearing!!!!
Here is my problem. After I added a fuel pressure guage and regulator I noticed I had over 9lbs when I the engine is first started so I adjusted to 5lbs. After driving awhile I noticed I the car was fuel starved and would not go over 30 MPH. I checked fuel pressure and noticed I had about 0. So I readjusted the regulator but can only get to about 3 or 4 lbs.(The regulator has a range of 4 to 9.) Sometimes the pressure still disappears.
I have changed the mechanical pump, checked the fuel filter. I have new lines from the pump to the carb.
What's going on?? Why is there 9lbs when engine is cold then drops to 0,1,2,3 max of 4 when warmed up?
Anyone had this problem??
Engine is a 351C 4V. Carb. is an Edel. 750VS.
Rancho Lenny is offline   Reply With Quote
03-07-2004, 12:38 AM   #2 (permalink)
My427stang
Do you run a liquid filled gauge? There has been a run of bad ones, especially XRP, when they heat up, the liquid expands and it measure the pressure difference inside and out. WHich is zero when hot. I chased the same thing on two until we figured it out, it was the gauge all along
03-07-2004, 09:46 PM   #3 (permalink)
torino501
might have some trash in the tank,might take a little while for the screen to plug while running,but if you let it sit a while the trash would kinda fall off of it.just a thought
torino501 is offline   Reply With Quote
03-09-2004, 03:36 PM   #4 (permalink)
wildosvt01_OLD
I am wondering why your using a fuel pressure regulator when you have a mech. pump that will normally put out 9psi?Is it a stock fuel pump?Or aftermarket high pressure/high flow?
wildosvt01_OLD is offline   Reply With Quote
03-11-2004, 03:06 PM   #5 (permalink)
Rancho Lenny
I installed a pressure guage because I was starving for fuel and couldn't get over 40MPH. .Once I intalled the guage, I noticed I had 9 lbs when I started the the engine. So I adjusted pressure to 5lbs. After driving I noticed the pressure dropped to 0, so I readjusted but the best I can get is 2 or 3 at idle. This is the problem I am trying to solve.
I am going to use a plastic gas can to suck up fuel right at the pump. If the pressure comes back, then evidently there is something wrong with the fuel line. I visually inspected the rubber hoses. They looked good, but I have been told that they can colape on the inside.
Any other suggestions?
03-11-2004, 03:18 PM   #6 (permalink)
Luv70sFords
pickup in the tank could be clogged, very common in older cars. Especially those that sat for any extended period of time.
03-12-2004, 02:44 PM   #7 (permalink)
Rancho Lenny
I replaced all the rubber hoses and blew out all the hard lines. It did not make a difference. I know I need to check the pick up and strainer, but can I remove this unit from the front of the tank if the fuel level is 1/4 or lower, without droping the tank?
03-12-2004, 08:50 PM   #8 (permalink)
Rancho Lenny
Still have the problem!!!
Today I pulled the pickup out of the tank. There is no screen. I had removed it when I first cleaned the tank about a year ago.
I looked inside tank and could find no foreign material.
The pickup tube is clear..
To date I have check everything from tank to fuel pump to carb. The only thing left is the Fuel Pump itself. It is stock one from Auto Zone.
Is there anything that I have missed???
Is it possible the I have installed the fuel pump incorrectly?
03-12-2004, 09:34 PM   #9 (permalink)
Luv70sFords
boy, heres a thought. Could the vent on your tank be plugged? maybe your drawing the tank to such a vacuum the fuel pump cant pull it anymore. See if your problem is still there with the fuel cap off.
