08-05-2006, 05:07 PM   #1 (permalink)
MontegoMan351
351c 2v headers and AOD swap
First of all, I am new to this forum and have a '73 Montego 351c 2v/FMX 4-door. I have a few questions that somebody may be able to answer.
Has anyone ever put headers on a 72/73 Torino/Montego with a 2v engine and a fmx trans.? All I can find are the ones that fit a C4 trans. Has anyone ever ran into this before. Any tips, part numbers, suggestions?
Has anyone swapped an AOD into a 351c equipped Montego or Torino? I am building my engine now and am building it to be a mild street motor. I am bumping the compression to 9.5:1, a mild cam, among other things. I was wanting to get info on this swap, so I could maybe start gathering parts now. I already have a 4R70W wide ratio planetary set. I would like to know what parts I need to get.
What year trans. is the best to get?
What driveshaft should I use?
What crossmember should I get?
I have built a EFI setup that ran great before the oil pump locked up due to a piece of valve stem seal getting past the screen. I am using a '93 Grand Marquis throttle body that already has an AOD throttle cable hole in the arm, so hooking that up should be a cinch.
I plan on breaking my engine in with the manifolds and swapping to headers later. Sorry for such a long post, but I figure someone on this forum will know something.
Any help will be greatly appreciated, Thanks in advance, Chris.
MontegoMan351 is offline   Reply With Quote
08-15-2006, 11:44 AM   #2 (permalink)
Radchero
I can help on some of the questions.
Look for headers designed to fit C-6 equipped cars. Generally, if they fit around a C-6 they will fit around the somewhat smaller FMX. I haven't looked up the part numbers but Hooker still offers 351C-2V headers for the 72-76 Torino Chassis.
I can't really advise you on the tranny upgrades but I suggest you post or do some searches on the Ford Tranny Forum:
Ford Tranny Forum
Also my 73 Gran Torino Wagon has an AOD. It was already installed when I bought it last April on Ebay.
Radchero / Kev
<font size=-1>[ This Message was edited by: Radchero on 8/16/06 1:45am ]</font>
<font size=-1>[ This Message was edited by: Radchero on 8/16/06 1:46am ]</font>
<font size=-1>[ This Message was edited by: Radchero on 8/16/06 1:47am ]</font>
<font size=-1>[ This Message was edited by: Radchero on 8/16/06 1:49am ]</font>
<font size=-1>[ This Message was edited by: Radchero on 8/16/06 1:50am ]</font>
Radchero is offline   Reply With Quote
08-15-2006, 11:57 AM   #3 (permalink)
Radchero
I've never encountered this before but the llink to the Ford Tranny Forum is bering replaced by something else.
Its www dot network54.com fordward-slash Forum fordward-slash 260730 -- you can figure it out.
08-19-2006, 05:58 PM   #4 (permalink)
ZephyrZ7
While not a Torino owner I did have a 351C-2V (with 4 bbl carb) 72' Mustang that I swapped a built AOD into. I originally had an FMX so the headers were for that trans, when I went to the AOD I had to cut off one small ear off of the bellhousing, it didn't serve any purpose that I could see except get in the way of my header! [img]/forums/images/smiles/icon_wink.gif[/img]
I had to flip the shifter linkage and I used a Lokar cable from the trans to the Holley 750dp.
Funny, on the box the carb came in it said "NOT FOR USE WITH AOD TRANS". pffft!! I made it work no prob! [img]/forums/images/smiles/icon_biggrin.gif[/img]
There is a fine line between a hobby.... and mental illness.
<font size=-1>[ This Message was edited by: ZephyrZ7 on 8/20/06 10:19pm ]</font>
08-23-2006, 09:28 PM   #5 (permalink)
MontegoMan351
Thanks for the help, I'll see what I can find out.
08-24-2006, 01:12 AM   #6 (permalink)
OleDutchD
Uh, I'm not so sure about the Hooker 351C 2V headers. I had a set of those in a Torino 25 years ago, but I thought that they had since been dropped from their current line-up. I could be wrong, but I don't think so.
If they're NOT available, call Stan @ FPA. He makes a killer set of headers... excellent workmanship...they fit... period! And Stan is a straight-up guy. He'll tell you what will/won't work, and he'll let you know ahead of time if there are any issues to be aware of and how to overcome them. He worked with me on my 351W/C6 header combo and I could NOT be happier! FPA lists specific 351C headers for this chassis in 2V and 4V configuration. No tranny or ground clearance issues, either! Give him a call....
http://www.fordpowertrain.com/Headers.htm
Kevin
PS... Try the Ford tranny forum @:
http://www.network54.com/Forum/260730/
OleDutchD is offline   Reply With Quote
