interchangable bell housings
there is to bolt pattern C-4s. SBF=289,302, 351W, 351C. A BBF that was put behind a few 351Ms that one fits 351M, 400M, 429, 460. Now there is 2 different C-4 main trans bodies. Pan fill and case fill. Case goes right into the right front corner of the trans and the pan fill screws into the right side of the pan. They have different bellhousing, pump botl patterns, 5 and 7 bolts. Pan fill will fit a BBF and the case fill doen't have a bellhousing for the BBF. Mainly because the pan fill is a little stronger casing. Now there is no C-4 bellhousing that fit the FE. C-6 has 2 bellhousings, BBF, 351M, 400M, 429, 460 and the SBF, 289, 302, 351W, 351C. Tomorrow we'll take flexplates so we all can be confused.
