Re: Header Gaskets
I had papers when I first got my Hookers, they were the ones that came with it. They worked fine untill a couple WOT blasts, then they started ticking. I ended up using an aluminum street sign I had lying around, and a thin smear of red high temp RTV.
'73 Montego MX 357C Homebuilt EFI, 9.5:1 comp, mild cam, 30lb injectors, A9L computer, Moates.net chip, 70mm TB, 76mm C&L mass air.
