09-18-2007, 06:38 PM   #1 (permalink)
MontegoMan351
'73 rag joint...help!!!
I've got a '73 Montego, the rag joint took a dump. So, I swung in to the autoparts store and got one, I got home and disassembled it...which is not fun...and I got it prepared to put the new coupler on. Well, long story short, it doesn't work, the safety pins are not the right size, the holes are too small. Arghhhhhhh, WTF???? Has anybody done this before? Thanks.
'73 Montego MX 357C Homebuilt EFI, 9.5:1 comp, mild cam, 30lb injectors, A9L computer, Moates.net chip, 70mm TB, 76mm C&L mass air.
MontegoMan351 is offline   Reply With Quote
09-18-2007, 07:01 PM   #2 (permalink)
Re: '73 rag joint...help!!!
Are the safety pins too large on both sides or just one? I've seen rag joints and tried to assemble them backwards with the same results you are getting...
Is one of the pins fatter than the other?
09-18-2007, 07:43 PM   #3 (permalink)
MontegoMan351
Yeah...the threads of the safety pin aren't long enough.
09-18-2007, 08:07 PM   #4 (permalink)
Is that the only rag joint they offer for your car?
Or was it a "HELP" rotisseri section pick that lists a hundred diffrent applications for Ford and Chebby and Dodge Etc... and you just pick the one with your make on it?
09-18-2007, 08:09 PM   #5 (permalink)
MontegoMan351
Yep, I got it off the rack...
09-18-2007, 08:11 PM   #6 (permalink)
Sorry bro... Looks like you're gona have to steer with a pair of vice grips back to town...
09-18-2007, 08:11 PM   #7 (permalink)
If you got any pics put them up and maybe we'll see something you can't... Not literally but figuratively...
09-18-2007, 08:13 PM   #8 (permalink)
MontegoMan351
I'll check tomorrow if there is any other rag joint...
09-20-2007, 06:47 PM   #9 (permalink)
MontegoMan351
I got a Lares rag joint (PN: 202 for a Ford gear, $30 at Advance) and I installed it, probably tighter now than it has ever been...so I'm happy.
Where to buy rag joint for \'65? ironmachineus Galaxie Pages 4 02-15-2007 09:42 AM
U-joint angle mattrobison All Ford Techboard 9 09-11-2005 10:02 AM
need U-joint girdles mikemustang289 All Ford Techboard 8 05-13-2005 02:56 PM
U-Joint Question Digimortality All Ford Techboard 3 09-14-2004 10:56 PM
U-joint U-Bolts? mikemustang289 All Ford Techboard 1 08-13-2004 11:42 PM
