Re: Disc brakes from 78 Lincoln
If you upgrading from drum to disc, hell the granada swap is perfectly fine.
A guy I know is into 50's ford and mercs, and he stopped using Granada stuff and started using mid 70's torino spindles instead to get the bigger 12" rotors, and swapped in alot of mark5 rear axle stuff into his 9" housings.
He said he did that because the torino stuff is still easier to come by than the Granada stuff and is usually cheaper, but if you have the G stuff, go for it.
