03-24-2008, 05:22 PM   #11 (permalink)
torinoracer
Re: 351C doesn't run
5psi is stupidly low, my cleveland has 20psi at warm idle and around 40-50 at cold idle. Something is not right with your motor, time for a tear down!!
BURN RUBBER NOT YOUR SOUL
torinoracer is offline   Reply With Quote
03-24-2008, 07:39 PM   #12 (permalink)
forddude
sounds to me from what you and the other guys have said in this thread.......the engine is wore out and you dont sound to enthused about investing a little wrench time to fix it. especially after reading about the low oil pressure and pieces of metel ect, ect. either tear it down and rebuild and fix it right or sell it and get rid of it.
Your ride is you, You are your your ride.
___________________________________
1966 Ford Galaxie. Frame off rebuild in progress.......and pieces.
forddude is offline   Reply With Quote
03-25-2008, 06:20 PM   #13 (permalink)
torinojimmy
deep down i knew it would come to a rebuild b/c even if i fix the popping, im not comfortable with driving it with 5psi oil pressure.
i'll try and scrape up a little extra money b/c once its out i might as well beef it up a little.
-if it turns out that i ultimately don't want the motor back in, what do you guys think of a 460-easy,mild or hard swap.
i have a 460 sittin in the corner from when i snatched it out of a salvage yard cause i saw it was freshly rebuilt(knew the guys and got it for $450-the lincoln drove in the yard!)
4.10's are highway gears
torinojimmy is offline   Reply With Quote
351c into 90 gt or lx fit or no fit fordduh Mustang Pages (1979-1995) 5 01-09-2006 06:34 PM
351c will not run.. Dave All Ford Techboard 3 10-31-2003 01:22 AM
351C-B-Gon Greg P All Ford Techboard 4 06-05-2003 11:54 AM
351C /w Aussies: Please help /w Spark plug T*, Chris Kelly or other 351C ppl. SteeLDawN All Ford Techboard 5 04-20-2003 04:38 AM
differences of 351C ´70 and 351C ´72 zICRONIx All Ford Techboard 3 11-28-2002 07:45 PM
