03-31-2008, 08:32 PM   #1 (permalink)
SLOWnSTEADY
'73 Torino/460
Hello, i recently aquired a 1973 Ford Torino. The car is in very nice shape with only 30K original miles but it is an inline 6. I have a 1984 F350 sitting outside with a milldy built 460/C6 that i would like to put into the Torino. Is there any place i can go that will have the info i need to do this swap? I have some engine swap experience:
5.0HO into a 1990 RX7
460/C6 into a fox body
383/T-5 into an '88 trans am (original 2.8L auto)
and my baby, a 3.4L DOHC (LQ1, TONS of mods with an intercooled turbo setup) into my 1987 Pontiac Fiero, originaly a 2.5L
Stuff i know (well, think) i will need:
motor mounts... factory big block torino mounts work?
Radiator... I assume teh 6 cyl. one will not work
driveshaft...
stuff i wonder about:
throttle linkages/kick down cable
rear end
trans mount(s)
SLOWnSTEADY is offline   Reply With Quote
04-01-2008, 08:23 PM   #2 (permalink)
tim1859
Re: '73 Torino/460
I have a 73 Torino that I put a 460 in. This will be tons easier than other swaps you have done. Because the 429/460 engine family was available from the factory in these cars the swap is pretty straight forward. I started with a 351C car, so you may have some issues I did not.
I bought factory motor mounts off ebay. They seem to be getting more scarce. Crites Restorations (Crites Restoration Products) sells mounts that adapt factory small block mounts to the big block.
I had to upgrade from the factory two-row radiator to a three-row unit. I got it pretty cheap from the Radiator Barn (Radiators, automotive radiators, condenser, oem radiators, truck radiators).
The trans member had two mounting positions. My 460/C6 wanted the rearward position. The mount was a standard replacement piece.
I used the existing throttle linkage, but I don't know if that will be possible with a 6-cylinder car.
I had a 9" sitting in the rear end. I don't know what they put in the 6 cyl cars.
I went to a local shop and had a drive shaft made. Around $200, I think?
I hope this helps
'73 Gran Torino Sport - 466ci, Performer Intake & Carb, Comp 268H
tim1859 is offline   Reply With Quote
04-01-2008, 08:55 PM   #3 (permalink)
dbu8554
Re: '73 Torino/460
rear end might be a 8 inch ive seen them before on i6 cars driveshaft should be had from maybe a junk yard also does anyone know if a 73 montego 4 door Driveshaft would be the same its a 400 c6 car but its some swap parts if ya need em let me know
AOD into my Torino slik Torino Pages 8 03-09-2008 08:41 AM
Will any body parts from a '73 Gran Torino wagon, fit on a regular Gran Torino? Blue71 Torino Pages 6 10-25-2007 09:18 PM
My Torino torinoracer The Garage 9 11-06-2006 06:04 PM
AOD in a 72 Torino 351cid All Ford Techboard 1 09-15-2002 10:20 AM
Torino and Gran Torino- what's the diff? slick mo fo Torino Pages 4 04-02-2002 05:36 PM
