04-06-2008, 10:02 AM   #1 (permalink)
RyanJ
'72-'76 Hood Clearance (big block, specifically)
I know there's a lot of room under the hood, but I'm curious if I'm going to need to cut and scoop to make room for an Edelbrock RPM intake on top of the 460 in my '75 Elite. I'm already sort of planning on having to, but I'd thought I'd ask. Any other big block guys here that have tried to fit it all under a stock hood?
1975 Elite - Factory-460 work-in-progress "resto-mod"
1994 Thunderbird - V8... future classic?
RyanJ is offline   Reply With Quote
04-06-2008, 10:43 AM   #2 (permalink)
ThenIsaid
Re: '72-'76 Hood Clearance (big block, specifically)
I have a 72 torino. I am lucky as the GT hood ads several inches of clearance. I am basing the following on my car with a flat hood and a 460 with rpm intake. It will fit as long as you don't run an air cleaner and don't mind removing the hood insulation. It will be very close to the hood and you will need to pull out the air cleaner stud. I would figure on adding at least a cowl type hood.
ThenIsaid is offline   Reply With Quote
04-06-2008, 11:30 AM   #3 (permalink)
RyanJ
Hood insulation is already gone, and yeah, an air cleaner would be nice to have... :-P
I figured as much. I've already looked a few hood scoop designs I'd be happy with. No cowl scoops, though. I'm trying to decide on a forward-facing style that compliments the lines of the hood as to not look any more out of place than it needs to be. Thanks for the input, though.
04-06-2008, 06:17 PM   #4 (permalink)
76grantorino
i am looking at the same problem but i went with the dual plane weiand intake. it fits but i cant use an air filter. post some pics of your scoop once its done. would love to see how other people are getting around this problem. all the scoops i have tried looked tacky. good luck
76grantorino is offline   Reply With Quote
04-06-2008, 06:59 PM   #5 (permalink)
RyanJ
I think the key to getting a scoop to look decent on these cars is to find one that is broad and "flat" as to not interrupt the natural lines of the hood. The early fox Mustang scoops aren't bad, but a little small. A much longer and wider scoop can gradually climb to the height required without looking like a plateau in the middle of the vast plane of sheet metal. I've got my eye on one called a "1967 Shelby Mustang style" that I think will look good. It's very long, wide, and a little over 3 inches high. I'll post something up when I have it.
04-07-2008, 11:38 AM   #6 (permalink)
76grantorino
There is a web site that sells fiberglass hoods anf trunk lids for torinos. there is even an option to select s scoop. my wife deleted the history and i cant find the page. does anyone know of this page and can give me the web address
04-07-2008, 11:50 AM   #7 (permalink)
75Squire
The BOSS 429 scoop is very wide and long and is also about 3 inchs tall. I know Summit sells them, not sure about who else.
75Squire is offline   Reply With Quote
04-07-2008, 12:15 PM   #8 (permalink)
RyanJ
USBody.com is what you're looking for. Unfortunately, a Torino hood is different enough that it won't work on my Elite, or I'd really consider going this route. That's a lot of extra weight off the front end!
07-27-2008, 02:14 AM   #9 (permalink)
76grantorino
does anyone have an idea of where this guy found the 67 shelby hood???
07-27-2008, 03:15 PM   #10 (permalink)
Mikelonis
FYI. I have a 460 in a 73 car and stock flat hood. I have the Weiand Stealth and a drop base air cleaner. It has clearance, very little, but it clears without a special hood.
Hood clearance dtitus Mustang Pages (1979-1995) 3 10-22-2006 05:29 PM
RPM Air Gap/Hood Clearance tbirdz12 Maverick Pages 5 06-24-2006 11:38 AM
hood clearance strokerman All Ford Techboard 3 07-04-2003 03:38 PM
hood clearance strokerman All Ford Techboard 2 03-13-2003 04:13 PM
351 hood clearance? mbereda All Ford Techboard 11 12-18-2002 12:49 AM
