06-06-2008, 01:16 AM   #1 (permalink)
Jeffhynes
Wiped Lobe, Stuck Lifter, Dropped Valve, Lions and Tigers and Bears Oh MY!
So, over the past couple days I've heard a ticking that has slowly worsened. It's now a very audible ticking sound that comes and goes depending on load, and the engine is audible missing (like alot of lope that it didnt have before).
I changed my oil today to see if that would help
Jeff
'68 Montego currently: 351w .030 over, performer rpm heads, small crane cam, intake, BG carb, C4, 8" w/ 2.79 gears cause I have to drive on the highway :(
Jeffhynes is offline   Reply With Quote
06-06-2008, 01:28 AM   #2 (permalink)
torkair
Re: Wiped Lobe, Stuck Lifter, Dropped Valve, Lions and Tigers and Bears Oh MY!
My guess would be either wiped lobes or your rockers need to be tightened. Take the valve covers off and wiggle the rockers by hand to see which ones are loose. Next have the car idle for a few minutes with the valve covers off and watch the rockers very closely, this should help you determine if any of the lobes are wiped.
For your sake I'm hoping it's just loose rockers.
torkair is offline   Reply With Quote
Wiped cam lobe? 69rangerman All Ford Techboard 23 01-08-2007 07:59 AM
Wiped cam lobe? giddyup1 All Ford Techboard 5 10-15-2006 05:30 PM
Wiped out a cam lobe UPDATE!!! Good News!!! kywookie All Ford Techboard 13 07-21-2004 09:11 PM
Update on wiped cam lobe... Pale Rider All Ford Techboard 9 01-22-2002 10:26 AM
wiped cam lobe, this f#$king sucks!!!!! Pale Rider All Ford Techboard 23 01-08-2002 10:27 PM
